Well, my temp. gauge gets pretty damn high for a Honda. WAY over half at times, but never in the "danger" zone. I added factory cruise and dude who did that chore took out my gauges and swapped speedometers only. The speed sensor on the LX's, which had factory cruise, is in the speedo. head itself, so that was necessary. Personally, I would have just swapped out the whole gaugeset with the LX one. But he actually used my old gauges except for the speedo...
I have replaced the thermostat and it has an OEM Honda one in there. I replaced the radiator, upper and lower hoses, new coolant. Water pump is maybe a year old. NO leaks, no oil in the radiator and vice versa, no smoke, no smell. The gauge just gets WAY too high for my tastes. The few people I talked to think the gauge is off a little bit, probably when dude did his swapping. I guess the fuel and temp. gauges are VERY sensitive and not really meant to be ever messed with. He didn't mess with the temp or fuel gauges themselves, but maybe the temp. gauge just got tweaked in the whole process.
So, I idled it for about 30 minutes and it's probably 70 degrees in my garage. Here are the results taken by my handy dandy laser, hand held point thermometer:
After about 5 minutes, I began taking readings.
140-160 at the radiator neck (L shape) after the fans run a cycle
162-174 at the valve cover. Didn't really matter about the fans running or not
125-130 at the upper radiator hose after the fans cycle
155-160 on the upper "tank" part of the radiator. Shaped like a hill...
100-106 at the cap after the fans cycle
150 at the fan shroud (metal part) after fan cycle
130-135 at the upper hose between fan cycling
155 at the fan shroud between fan cycles
160-170 at the radiator neck between fan cycles
108-111 at the cap between cycles
I know you're saying that I should have left the cap off to measure the coolant temp. itself and used the 11:1 D to S reading for better accuracy and whatnot. It started out like that, but the coolant was running out of the neck in the first couple minutes. The car has been sitting for 2 or 3 days in the garage. I put the cap back on and just took various readings in those 20-25 minutes on everything around the fluid (as close as I could get). Both fans run and cycle on/off as they should and there was no AC on. SO, looking at all that I think I'm good, right? The guy at Honda said if it gets over 195, be concerned. I thought it was 185 when the thermostat kicked on, but nothing ever got close to those numbers (and I took readings almost constantly). Of course, he assumed I could beam up the coolant itself. Could the coolant at the neck, inside the radiator, be 30 degrees hotter than the neck itself? That would be significant, but everything seems just fine except that damn gauge!
