Hey guys! Hope everyone is doing well. I've searched but did not find this kind of problem. I’m having issues with my car especially when starting in the morning. When I start it in the morning, the engine would vibrate and sputter. The idle speed would also drop and if I put the gear in reverse the engine would die. If I’m lucky enough, I will able to drive the car for 3 minutes(with the engine vibrating and sputtering) and the engine would stall. It doesn’t really help if I step on the gas pedal coz the engine still vibrates/sputters. What’s weird is, this would only happen when the engine is not fully warmed up. The car runs fine when the engine is fully warmed up. The spark plugs, spark plug wires, cap, rotor, fuel filters, air filter and motor mounts were replaced last year. I also have a new battery. I sprayed some carb cleaner but it didn’t help at all. I also check for vacuum leaks on the hoses but wasn’t able to find any. Do you guys have any ideas? Thanks in advance!
