Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
Thread: New here (pics)
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: New here (pics)
    Quote Originally Posted by mikes87lude
    Wouldn't the light flywheel help it to spool up on acceleration.
    Thanks for the welcome. Is this your home away from PP? Rich finally talked me into joining 3geez, I like it so far.
    ya the flywheel will make it spool up faster, but it will also make it spool down faster...too fast more than likely for a turbo application.
    '89 SE-i Coupe
    Awaiting Garage
    Feb 2007
    '87 lude/'95 Accord V6
    Houston, Tx.
    Re: New here (pics)
    OK. I'll put off the flywheel, it'll save me $275 by not buying it.
    On a different note, kinda off subject, does anyone know where I can get a fifth gear for a 3g Accord? I hear that the gears from a 3g Accord are interchangeable with those in a 2g Prelude. I'd like the Accord 5th because it would be better for highway use. When I shift from 4th to 5th with my current gears the engine RPM only drops about 500. It sucks doing 80 mph and the engine screaming at about 4100 RPM.
    Bottles are for babies....Real men get blown!
    LX User Estimated Prophet's Avatar
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    Re: New here (pics)
    http://www.hondapartsdeals.com - They're around $60-70 per shaft.
    Honda Parts Connection -- http://www.acurahondaparts.com
    D Series Army Dishonorable Discharge
    BT Defector
    Feb 2007
    Houston, Tx.
    Re: New here (pics)
    Thanks for the link (added it to my favorites list) $67 isn't bad, even after shipping shouldn't be more than about $80.
    2drSE-i's Avatar
    Oklahoma City
    Re: New here (pics)
    for a transmission, you can swap integra gears into our gearboxes. If you use integra gears 1-4 (their really close together) or 1-3 (some people like accord gear #4, just because its further apart, higher top speed) you can use that for a good hybrid tranny. Integra setup is definately better for acceleration.
    '89 SE-i Coupe
    Awaiting Garage
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    Re: New here (pics)
    For a turbo he'd probably want to keep the stock gears.
    BT Defector
    Feb 2007
    Houston, Tx.
    Re: New here (pics)
    Quote Originally Posted by Estimated Prophet
    I like the stock gears, except for fifth, they are close enough in ratio for me. Anything closer and I'd be doing 20 Mph shifting out of 3rd. (joke) Fifth I want to be more of an overdrive than it currently is. When you shift to 5th it seems as though there should be 1 more gear.
    Mmmmm Ssiiixxx Sssppeeeedd
    Wish it was possable, I start to drool everytime I think about it.
    Sorry.
    Anyway. yeah. Better fith gear ratio, gotta have it.
  8. #33
    Re: New here (pics)
    Sorry.
    lude gears are a bit shorter. if you want to spool up that turbo you might have to get a accord tranny.
    Nov 2002
    Ridin Dirty in New York
    Re: New here (pics)
    yeah i wouldnt go any shorter than a lude tranny. That has shorter 3rd 4th and 5th. I personally have a carbed tranny (longest gears of all). Thumbs up to this thread!! finally a noob that knows somthing
  10. #35
    2drSE-i's Avatar
    Oklahoma City
    Re: New here (pics)
    im surprised with how much i actually knew and coul help him with. it sounds to me like he wants a longer 5th gear, so id say go carbed accord 5th gear.
    '89 SE-i Coupe
    Awaiting Garage
  11. #36
    Feb 2007
    Houston, Tx.
    Re: New here (pics)
    ...Thumbs up to this thread!! finally a noob that knows somthing...
    ....it sounds to me like he wants a longer 5th gear, so id say go carbed accord 5th gear.....
    Thanks for the props, and the advice. Would an '87 carberated Accord 5th gear, in your opinion, be along the lines of what I'm looking for? I like to do what a lot of "Noobs" don't, that is RESEARCH. Also, this isnt the first car I've built. I've been a mechanic for 12 years. In the past it's been mostly V8s.
  12. #37
    2drSE-i's Avatar
    Oklahoma City
    Re: New here (pics)
    well the carbed gears are spaced further, and you said you wanted a longer 5th gear for the highway, so that should be the perfect match.
    '89 SE-i Coupe
    Awaiting Garage
  13. #38
    Feb 2007
    Houston, Tx.
    Re: New here (pics)
    Good. Research complete, I'll wait until I pull the motor for rebuild and do the tranny at the same time. May as well get the parts now though. Thanks again for the link Prophet.
    Mike
  14. #39
    2drSE-i's Avatar
    Oklahoma City
    Re: New here (pics)
    hahaha research complete my ass...youve got a long way to go, you just dont know it yet lol
    '89 SE-i Coupe
    Awaiting Garage
  15. #40
    Feb 2007
    Houston, Tx.
    Re: New here (pics)
    Well the 5th gear part of my research is complete. I'm always looking for better ways to do somthing.
    Example: Just finished reading a thread where dude used a '86 tempo dizzy on his A20. I've been looking for ignition timing control that didn't involve using a BTM. MS can do ignition timing, I just don't have a dizzy that will allow it. Now I have a new direction to research on my ignition issues.
  16. #41
    Nov 2002
    Re: New here (pics)
    afaik, carbed and fi trannies are the same gears EXCEPT the final drive is longer in teh carbed tranny... I do know for a fact that a lude si tranny has shorter gears in 3rd 4th and 5th compared to fi and carbed accord trannies. If you want a longer 5th you should use a complete carbed accord tranny, which actually isnt soo bad because 1st and 2nd are a little longer than the fi tranny and lude tranny (i believe fi accord tranny and lude si tranny are the same 1st and 2nd gear and final drive possibly) and will help with traction. So a carbed tranny is probably your best bet if you want a longer 5th
  17. #42
    2drSE-i's Avatar
    Oklahoma City
    Re: New here (pics)
    shows what i know. I was just jackin with ya, didnt mean anything rude by it.
    '89 SE-i Coupe
    Awaiting Garage
  18. #43
    Feb 2007
    Houston, Tx.
    Re: New here (pics)
    ......If you want a longer 5th you should use a complete carbed accord tranny, which actually isnt soo bad because 1st and 2nd are a little longer than the fi tranny and lude tranny (i believe fi accord tranny and lude si tranny are the same 1st and 2nd gear and final drive possibly) and will help with traction. So a carbed tranny is probably your best bet if you want a longer 5th
    The lude does spin the tire (right one only) all the way through first, and the first couple hundres RPM of second. So take off is also an issue. I've been searching for a Phantom Grip, or something similar, to resolve this problem. I'll look around and see what I can get a carbed tranny for. If I don't like first and second I can always put the lude gears back, and just use the accord fifth. Thanks.
  19. #44
    Re: New here (pics)
    yeah the carb trannies have the longest gears. good for high reeving and keeping the boost up between shits.
    Feb 2007
    Houston, Tx.
    Re: New here (pics)
    I found a carb tranny for $250, but I think I'll keep looking. I probably can find one cheaper. What about clutch and flywheel, are they the same, or will I need to buy a different flywheel, clutch, and pressure plate to go with the carb tranny?
  21. #46
    2drSE-i's Avatar
    Oklahoma City
    Re: New here (pics)
    it should work. just hit up a junkyard. Youll have to do alot of work yourself, but even if you get it rebuilt you should save some money.
    '89 SE-i Coupe
    Awaiting Garage
