this happened at 70 mph on the freeway. during a turn, no less. i was on an interchange. as a result, i need a new shock.
eek shyte!
I have no idea what im looking at.. Does that black thing with the spiral tube or whatever compress the springs?
did it brake or did the nut fall off and why do u have a spring compressor on the spring while its on the car
if u look in the middle of the spring the top of the strut is viable and that not supposed to happenOriginally Posted by ahmad89
apparently nut was loose, so yeah, it fell off. and spring compressor is because w/o the shock, the spring decompresses (remember, you have to compress it to put it on the shock...) and it becomes damn near impossible to get the screw at the bottom out that connects the shock assembly to the hub. as it was, it took a good fifteen minutes of grunting + lots of grease, drywall screw, and impact wrench to get it out.Originally Posted by ghettogeddy
correct. and you're also looking at the top of the shock in the middle of the spring, while it's on the car. that isn't normal.Originally Posted by ahmad89
i guess i never thought it would be hard to take it off with out the strut
Even if the nut did fall off I don't think that would be the cause of the shock being completely compressed like that. I think that the shock could have possibly failed. After the gas was forced out of the shock, the spring decompressed and snapped off the nut on the end of the shock. This is because the shock couldn't decompress because it couldn't fill itself with air. I could be completely wrong though. I'd have to see it in person.
outch....time for a tokico set up.
Heh..I didnt know thet was possible, but it is.
This is a critical obgect. need to do this properly!!!
My Build Thread
Wow.
that happen to me on my coilovers but it was on the back
not on this car. it's headed for the crusher...Originally Posted by MessyHonda
