Results 1 to 18 of 18
Thread: Displacement VS. Compression
    LXi User DDRaptor's Avatar
    1988 Honda Accord LX
    Bronx, NY
    I have had a few crazy build ideas including a 200ft-lb daily driver, but my question is this what is more reliable a A20 with 2.2l disp. with a slightly higher C/R of maybe 10:1
    or a stock disp A20 with a higher C/R of maybe 11:1
    what would be better for daily driver/sleeper??
    of course this would be part of complete bulid
    with Full head P&P
    oversized valves with waisting "Ti"
    Titanium Valve springs and guides
    Camshaft grind (paeco power at 2500 rpm.
    piston of above choeices
    hp oil pump
    and other misc. don't remember everything of the dome right now.
    89LX or SE-i(yeah right)
    Re: Displacement VS. Compression
    .50 over is prob like the max you can go on these engines. and that would only get you up to like 2.1L.....i would do both....i saw on a piston site that you could get like 20-30 hp with a .30 overbore and slight bump in compression.
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    well overboring on this engine wont get you all that far but if you'd go with a 30 over 11 to 1 compression should get you some nice results. If you can get some good tunning maybe 11.5 to 1 and maybe 40 over tops but thats pushing it as far as daily driver.
    like messy said even a 50 over over bore is only 2.1 L and a 30 ovver is like 2250-2275 cc's.
    If u plan on serious overborring I suggest balancing to keep the rotating assembly from putting to much strain on the weaker cylinder walls.
    bottom line is 30 over is safe daily driver and 11 to 1 is still a little forgiving as far as tuning.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    As the old saying goes. "There aint no replacement for displacement".
    Edit- Anything is possibly with good blueprinting & tune.
    http://victorylibrary.com/mopar/otto-c.htm
    not really clear on this chart but higher you go less benifits in general. Also remember some of the numbers you see are for domestics which usually have very low hp to cu inch ratings compared to Honda motors.
    Id be interested to se if you could run 11to 1 on pump gas (prem).
    youll get alot more torque than that with some decent boost levels (10psi+)
    you turbo NAZI!
    Vanilla Sky's Avatar
    1999 Penalty Box
    I think with proper fuel and timing control, 11:1 on pump gas is easy. I believe my mom's J30 runs 10.3:1 on regular unlreaded (premium isn't mentioned in the manual for the car).
    Something as simple as a knock sensor and an wideband O2 sensor will get you tuned in and keep you up to date if you start to predetonate.
    Maybe I should get into programming and tuning...
    I'd like to see it done and make power. By that my example is i have a Chrysler 440. It has whats called "10 to 1" pistons. There really not but that what there advertised as. While that sounds good for performance in reality I have to run the timing so far back it kills power alot. Running a big cam helps some but its still a comprimise I wouldnt recommend unles you like mixing in race gas all the time.
    I think like you said FI,aluminium heads and a good quench combustion chamber it could be done but I'd like to see it. And then its back to my original arguement the differance between 10 to 1 and 11 to one might be 10 hp might be more but I'd guess on our cars that be about it.
    Feb 2004
    89 accord lxi
    down by the bay
    are those domed pistons on the 440? i know that will give you a really slooowwwww burn rate.
    Vanilla, you should. then you can teach me.
    1999 Penalty Box
    lol, i'd teach, but i'd sell units that you have to have to program. there's just such a competition with aftermarket engine management that the small guy has a hard time competing.
    Quote Originally Posted by Strugglebucket
    Naw almost as bad. There the old heavy ass TRW piston that really give you like 8.5 to 1 compression. There prolly like .100 down in the bore for like you said the worst burn rate ever and ping like a pig. Some day Ill fix all that. It was a common motor build in like 1984 . Trw's a .509 cam headers and 906 heads. Quench motors and alum. heads are the way to go.
    Bronx, NY
    HUH well that shows how much i know. lol. amongust my friends i'm an engine guru among you guys i'm a novice.
    bottomline safest n/a bet for 165whp-ish 20/30 over with 11.1 C/R
    Quote Originally Posted by DDRaptor
    yup...openloops car is around 10.5 compression
    Bronx, NY
    sounds like a feasible goal, thanks alot.
    i've been posting lately Am i making some lame threads??
    http://www.theoldone.com/
    read some of the articles on this site esp. the ones on head flow and piston design. I really like what they do and they make good NA power.
    Another thing to follow is like NHRA Pro stock or some of the other NA fwd drag racers. There always on the cutting edge of motor performance.
    Power is in the head (flow) and the camshaft. The rest is just support.
    It is funny to see what was considered a prime motor setup just 10 years ago is so differant today. with computer modeling design just goes in leaps and bounds. Ic motors have been around what 100 years but they have made so many advancements just lately its incredible.
    Bronx, NY
    THat site is amazing i want his job bad.
    they need to fix their navigation stupid always poping up.
    Yeah I cant never use there compression calc it never works. I have thought about using them if I ever get a supercharger on my car.
    The Pro stock T-bird write up is really good as well not Honda related.
  1. WA State proposed engine displacement tax
    By TWOLOUDNPROUD in forum Classic Honda Community Chat
    Last Post: 02-13-2008, 10:53 PM
  2. compression
    By sinisterfuzzy in forum Performance
    Last Post: 09-23-2006, 07:25 AM
  3. changing displacement??
    By SIBILANTx in forum Performance
    Last Post: 08-19-2004, 05:08 PM
  4. displacement???
    By od2681 in forum 3geez Accords
    Last Post: 08-12-2003, 08:30 AM
  5. compression
    By b20a86lude in forum JDM B18A / B20A Swap Tech
    Last Post: 03-03-2003, 03:07 PM
