Ok so when i put them back in and plug them back in and then jump that plug you were talking about. What if both fans dont turn on? Do i replace that plug? Also what if the fans do turn on but when the car gets to the temp. where they should turn on but dont, what could it be?Originally Posted by LX-incredible
Thx LX-I but the problem is i took out battery cables cause the positive end is broken and in the manual it says to test to the thermo sensor i have to turn the ignition switch to on. I'll just reconnect the cables and wrap the positive end on the battery, i
ll keep yall updated.
If they don't come on when the sensor connector is jumped, test the fan relays. I posted how on one of your earlier threads. It they come on when jumped, replace the sensor on the radiator. If both fans come on with AC, the relays are good.Originally Posted by ahmad89
I'm not really understanding you. Make sure not to connect the sensor directly to the fans, the sensor sends a signal to the relays and they operate the fans. You will damage the sensor if you try to do so.Originally Posted by ahmad89
Im not gonna test the sensor without new battery cables cause i dont wanna risk a short or anything.
I got the negative battery cable waiting for the store to call me when the positive cable comes in which should be in an hour or 2. How can i test to see if my thermo sensor is working? Should i follow the manual or is there an easier way?
Come on man, I'm not feeding you BS here. I have had these same problems and am willing to share my knowledge, please don't make me answer questions more than once.Originally Posted by LX-incredible
I know your not im just seeing if theres another way to test my sensor, im going to test it tomorrow after i try to figure out why my car takes forever to start up. Dont think that i dont appreciate or take your advice and knowledge because i do and i really appreciate every advice or help you and everyone else give me.Originally Posted by LX-incredible
Im going to update this thread from now on.
https://www.3geez.com/forum/showthread.php?t=60429
