After reading my brochures I figured I post the official HP, Torque, & Weight Specs that Honda gave, but one thing that I don't understand is this:
Why is the 1989 Accord LX-i & SE-i's Motor rated @ 120HP when the 1988 is rated @ 122HP?
But heres the Specs
1986 Hatchback:
1986 Honda Accord DX: 98HP @ 5,500RPM/109 LB-FT @ 3,500RPM/2,416 LBS
1986 Honda Accord LX-i: 110HP @ 5,500RPM/114 LB-FT @ 4,500RPM/2,454 LBS
1986 Sedan:
1986 Honda Accord DX: 98HP @ 5,500RPM/109 LB-FT @ 3,500RPM/2,421 LBS
1986 Honda Accord LX: 98HP @ 5,500RPM/109 LB-FT @ 3,500RPM/2,529 LBS
1986 Honda Accord LX-i: 110HP @ 5,500RPM/114 LB-FT @ 4,500RPM/2,568 LBS
1987 Hatchback:
1987 Honda Accord DX: 98HP @ 5,500RPM/109 LB-FT @ 3,500RPM/2,416 LBS
1987 Honda Accord LX-i: 110HP @ 5,500RPM/114 LB-FT @ 4,500RPM/2,498 LBS
1987 Sedan:
1987 Honda Accord DX: 98HP @ 5,500RPM/109 LB-FT @ 3,500RPM/2,421 LBS
1987 Honda Accord LX: 98HP @ 5,500RPM/109 LB-FT @ 3,500RPM/2,529 LBS
1987 Honda Accord LX-i: 110HP @ 5,500RPM/114 LB-FT @ 4,500RPM/2,568 LBS
1988 Hatchback:
1988 Honda Accord DX: 98HP @ 5,500RPM/109 LB-FT @ 3,000RPM/2,416 LBS
1988 Honda Accord LX-i: 122HP @ 5,800RPM/122 LB-FT @ 4,000RPM/2,498 LBS
1988 Sedan:
1988 Honda Accord DX: 98HP @ 5,500RPM/109 LB-FT @ 3,000RPM/2,421 LBS
1988 Honda Accord LX: 98HP @ 5,500RPM/109 LB-FT @ 3,000RPM/2,577 LBS
1988 Honda Accord LX-i: 122HP @ 5,800RPM/122 LB-FT @ 4,000RPM/2,663 LBS
1988 Coupe:
1988 Honda Accord DX: 98HP @ 5,500RPM/109 LB-FT @ 3,000RPM/2,493 LBS
1988 Honda Accord LX-i: 122HP @ 5,800RPM/122 LB-FT @ 4,000RPM/2,646 LBS
1989 Hatchback:
1989 Honda Accord DX: 98HP @ 5,500RPM/109 LB-FT @ 3,500RPM/2,513 LBS
1989 Honda Accord LX-i: 120HP @ 5,800RPM/122 LB-FT @ 4,000RPM/2,641 LBS
1989 Sedan:
1989 Honda Accord DX: 98HP @ 5,500RPM/109 LB-FT @ 3,000RPM/2,500 LBS
1989 Honda Accord LX: 98HP @ 5,500RPM/109 LB-FT @ 3,000RPM/2,579 LBS
1989 Honda Accord LX-i: 120HP @ 5,800RPM/122 LB-FT @ 4,000RPM/2,685 LBS
1989 Honda Accord SE-i: 120HP @ 5,800RPM/122 LB-FT @ 4,000RPM/2,718 LBS
1989 Coupe:
1989 Honda Accord DX: 98HP @ 5,500RPM/109 LB-FT @ 3,000RPM/2,493 LBS
1989 Honda Accord LX-i: 120HP @ 5,800RPM/122 LB-FT @ 4,000RPM/2,646 LBS
1989 Honda Accord SE-i: 120HP @ 5,800RPM/122 LB-FT @ 4,000RPM/2,7?? LBS
All Data is provided by the Honda Brochure for the respective year
All Weights are with 5 Speed Manual and to not reflect the 4 Speed Automatic
If you have the official Weight for the 1989 Honda Accord SE-i 5 Speed Manual Coupe, please post it
Thanks All
Forrest
