89 lxi fuel injected manual tran...
Has been running fine. I get in this last Friday morning and it won't start. Everything powers up fine, push in the clutch & turn the key, nothing.. does not even try. Battery, altenator, cables .. all new.. i took out the starter and had it tested, works great. Some said the neutral safety switch. So i take off the button 'switch' located by the clutch pedal.. button was stuck out as plug in pedal assembly was gone so it never did push in the button..
My question is this, without the neutral safety switch being installed, or with the button out, or with me running a wire to connect the two-wire connection.. should the car start?? Because it won't. I want to know, before i spend the money for a new switch, that it absolutely Has to have one and a good one to start! if anyone can help, i would Really appreciate it.
Thanks,
vance
