Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
Thread: TW Sensor!
    epic1400cs's Avatar
    Jun 2004
    1989 CA5 Aerodeck EXi 2.0 A20A4
    London, UK
    Re: TW Sensor!
    That is actually what have happened to mine - after installing the new sensor the connector wire snapped.
    Push the two pins backwards then the two wires clamped against the pins came out with rubber insulation which was inside of the green plastic outer shell of the connector.
    Broke the black rubber, removed the wires carefully from pins, soldered new wires to the pins, inserted back into the green plastic connector and filled the empty gap where black rubber was with Shoegoo in black - not sure if it is heat resistance though.
    Then soldered the new wires with the connector to the healthy part of the wires on the car, phew.
    Also noticed that to install the sensor, I needed special sensor wrench or crowfoot wrench, otherwise the top plastic part of the sensor will be broken like my old sensor.
    carotman's Avatar
    Montreal South Shore
    Re: TW Sensor!
    If you actually need to replace part of the connector, a company called Cycle Terminals has almost everything you may need.
    For the TW sensor in particular check here:
    Motorcycle .090 - 2.3mm Connector and Terminals
    I need these parts!
    conozo's Avatar
    Fort Wayne, Indiana
    Re: TW Sensor!
    This amazon link is the correct part.
    https://smile.amazon.com/dp/B07W7RL6..._IMswFb73E1DEV currently $12 amazon prime. It looks to be the same part in similar OBD 0 and OBD 1 honda cars.
    Listing Description
    SEEU. AGAIN Engine Coolant Temperature Sensor 37870-PJ7-003 Compatible with Honda Accord Civic CR-V CRX Insight Odyssey Pilot Prelude S2000 / Acura CL Integra Legend MDX NSX RL TL Vigor/Isuzu Oasis Alternate/OEM Part Number(s): 213718, 25174240, 37870PJ5003, 37870PJ7003, 37870PK2005, 37870PK2015, 5862028470.
    1988 Honda Accord LSDX-I
  1. cylinder position sensor and TDC sensor
    By newaccorddriver in forum EFI Tech
    Last Post: 04-21-2011, 10:02 PM
  2. Coolant temp sensor tw sensor
    By Bluntman in forum 3geez Accords
    Last Post: 07-06-2009, 06:12 PM
  3. cylinder position sensor and TDC sensor
    By newaccorddriver in forum Classic Honda Community Chat
    Last Post: 11-28-2006, 10:29 PM
  4. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
  5. Quick, Which o2 sensor is the primary sensor
    By 89accordlxi in forum 3geez Accords
    Last Post: 11-03-2002, 07:23 PM
