Results 1 to 4 of 4
Thread: battery drainage
    LXi User coope's Avatar
    Sep 2006
    89 accord lxi efi
    mississippi
    battery drainage
    Every since i got the car every two weeks or so i go out side to crank my baby and the battery is dead as hell so i traced the wiring nothing it touching or enything no lights being left on i don't kno what is wrong i replaced alt.and such so it's good check fuses i don't kno what to do helllllp pllllleasssss........
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: battery drainage
    Sounds you like have some parasitic draw. To test for it, you'll need a digital volt meter. Unhook the positive battery cable & hook the leads between the cable & battery. Wait about 5 minutes, put the meter on amps. Anything over 50 milliamps is excessive.
    To find where the draw is coming from. Have someone watch the meter, start pulling fuses out one at time. When the amp reading drops, that is the circuit that is the problem.
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    How old is the battery. They can develope near shorts that slowly drain your batt. This happens on 50% of the batteries that I have replaced.
    Sep 2006
    89 accord lxi efi
    mississippi
    the batt. is brand new i'll try what d dud said thanx guys
  1. battery light on after purching a new battery.
    By 60408CC in forum 3geez Accords
    Last Post: 10-04-2009, 09:26 PM
  2. Battery light still on after replacing battery...
    By offthahook in forum 2geez Accords
    Last Post: 09-23-2007, 08:42 AM
  3. Front Sunroof Drain Location and simple drainage fix
    By Mike87accordlxi in forum 3geez Accords
    Last Post: 06-04-2005, 08:12 PM
  4. Replies: 19
    Last Post: 05-03-2004, 05:55 PM
  5. Replies: 6
    Last Post: 04-25-2004, 07:23 PM
