I need feedback.
I want to add aftermarket gauges. I want to know what has given good results for you. i have tried a temp gauge from the net and it did not read right with the factory sending unit. Is/are there any gauges Oil press., oil temp. ( iknow there is no factory sending unit for this one) and water temp that will just "slide" in.
That is , work with our sending units and give good readings. I can wire ,etc. this is question of compatiblity more than anything else.
Or is there a gauge that has a sending unit that will fit our spot.?
I would love black face, and and fade to all bl;ack at shut down (looks like a black hole) but these things are not critical, function is.
All thoughts and input will be appreciated, Thank you.
