i was trying to put my left hand side axle back in and it seems to long? just swaped from a20a2 to a20a3 are the bottemends the same?
Are they both from the same kinda gear box?Originally Posted by a20aaccord
The LH side is different between Auto Gear Box and Manual Gear Box
yea i swaped the same box over
I can see any reason for them to be diffrent?
I guess compare a shaft from each transmission?
i only have the one tranny. i had a a20a2 with the manual box on it. and then i swaped engines a20a3 used the same box.
NZ members go see whats a matta !!!
hopefully nothing has come apart in the transaxle, you try puting the trans in neutral, or if it is, put it in second, or park if its auto.
Is it not going in all the way on transmission side? Are you putting the correct end, in?
maybe its not going in cause of those annoying rings on the ends of the axles
yeah, probably the snap ring is being a bitch. Just slap it in!
I need these parts!
What the hell does this have to do with 1g Accords???
sorry put it in the wrong place. think found the problem my inner cv had came appart a lil havnt tryed putting it back in get tho
I hate axle work
got axle back in!! thanks 4 all the help![]()
So what was it? I know i pushing the axle into my tranny while my brother held it up on the other side.Originally Posted by a20aaccord
my inner cv had come apart a lil. hope its still ok
I would get it rebuilt, or get a new one... there's probably some bad reason why it came apart...Originally Posted by a20aaccord
not supposed to come apart, it usually takes work to get it apart, better look at it good.Originally Posted by a20aaccord
It comes apart, but can he be sure it all went back together properly without removing the boot??Originally Posted by guyhatesmycar
i slid the boot back and had a look it looks all good didnt c any probs,
took it for a drive today first time since i got the new engine, cv wasnt making any noises was pretty smooth so wont worry bout getting it rebuilt yet
good stuff![]()
