Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
Thread: need help
    1988 Honda Crx Dx Mini-Me
    Columbus, Indiana
    Re: need help
    Good luck...
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: need help
    check comoression,
    first disconnect the coil wire so that the engine wont start,
    then remove one plug and have someone crank the engine while you have the compression tester in the plug hole, do this for each cylinder and read/write down the reading for each hole.
    Also, remove the fuel pump relay.
    CAH, that type compression tester sucks & isn't real accurate. If you can, get one that screws in the plug hole.
    Columbus, Indiana
    Re: need help
    I Second this...
    Re: need help
    where the heck is the fuel pump relay lol
    and thats the best i can do on the compresion tester i got no money right now lol
    Re: need help
    it was probably all that reving you did sitting in place like in the video. it won't start with a blown head gasket because it doesn't have any compression. if theres oil leaking out of the head,i'm sure it's blown.
    Columbus, Indiana
    Re: need help
    That's what i'm thinking, it'll still run and drive but you'll have to get it to start everytime... if it's a 5spd park it on a hill.... if ya know what i mean lol
    Re: need help
    we had a 85 subaru GL with blown heads and it still started and we drove it like that for months untel oil started pooring out the carb then we parked it for 3months some one came wo buy it and it started right up
  8. #33
    Re: need help
    maybe it depends where the gasket is blown.. but dude if you have oil coming from where the gasket is, what else could it be?
    maybe you can sell it to the state for $1000 now.
  9. #34
    Re: need help
    it is not sue for a smog check untel 2009 O_O
  10. #35
    Re: need help
    that sucks that u didnt get forrests car yet dont spend any money fixing this one just spend it on getting that other one even if it means having your dad take a bus or something over to forrests place
  11. #36
    Re: need help
    i'm not puting anymore money in to this car thats for sure tonight i am taking all my shit out of it, the car just has to last intel we move so just back and forth to his work and once to the store a weak it should be fine like i said we drove the subaru for months
    i took some pics of the leak when my step dad was on his lunch break...
    i started the car this time it started then it stalled real quick like it lost all spark or the battery cut out so i am think the stalling and starting problems are from elec maybe a bad ground? or the ecu
    anyway on to pics
  12. #37
    Re: need help
    when u washed the engine u prolly broke the seal of old dirt and oil
  13. #38
    Re: need help
    funny thing is thats what i was thinking lol
    b-4 then the engine was never washed
  14. #39
    Re: need help
    Yea check compression. From what i remember you said your car didn't have any oil and it started to knock, which i assume isn't good for the engine. Oil leaking from the head is most likely the head gasket since oil does run down from the head to the oil pan.
  15. #40
    Re: need help
    If that is the case then
  16. #41
  17. #42
    Re: need help
    Well plugs look ok to me prolly lean if anything.
    The head gasket pictures or leak what ever that is. You didnt use blue permatex on the head gasket??? cuz i see something blue on the seem.
    That leak is most likely the distributor to head gasket. You can use permatex on it in fact I would recommend it. Its a common leak path.
  18. #43
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: need help
    Isn't the oil passage on the intake side of the block? You need to completely clean that mess up if you want to find your leak. It looks to me that it is coming from the distributor seal, an $8 part.
    CARDONE SUCKS.
  19. #44
    Re: need help
    Quote Originally Posted by LX-incredible
    is that honda price...i need to get one. but im also in the process of upgrading my whole top half of my engine. everything is going to be new i hope.
    Sep 2006
    Tucson, AZ
    Re: need help
    If we are talking about the shaft seal, Honda doesn't sell them, they sell you the whole dizzy instead. Drivewire and some others sell them for around $8. Honda only sells the O-rings.
    CARDONE SUCKS.
