Results 1 to 17 of 17
Thread: Vacuum Holding Cannister
    Lightbulb Vacuum Holding Cannister
    i finally got my stupid pictures to upload by some miracle.
    anyway,here are some of the vaccume storage bottle for the power brakes.
    the firewall feed through i made,this bolts to the firewall
    here is the bottle and the aluminum brackets i made to hold it in place
    sorry about the condition of the carpet,it's going to be replaced anyway,and sorry about the blurry image,still trying to get used to the focal length of this camera
    this mounts the floor behind my seat
    Re: some pictures of the vaccume bottle storage thingy
    cool
    going to try and hook up the lines today
    LXi User coope's Avatar
    Sep 2006
    89 accord lxi efi
    mississippi
    what does it do
    oh, i anticipate some vaccume problems with the dual carbs and the other cam going in,this helps store vaccume for the brake booster,so your booster always has enough vaccume even if you have a lower then normal manifold vaccume. there was no where to mount it under the hood,so it's mounted behind my seat,no one can sit behind me anyway with the seat all the way back.
    that does it,my tax refund check will be here in a week,auto carpet originals HELP!!!!
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    hey let me know how that works, I really need something like this after all the work on my motor even with a stock cam i only pull like 12 in/Hg
    it should work good,people have been doing it for years,if you use it for your power brakes,you t it into the line then the check valve goes into the line before the t,in other words the vaccume input on the booster and the bottle are attached together. if you don't want to fabricate one,you can buy one ready made from summit racing,or jegs.
    some more pictures of the vaccume bottle being installed
    feed through from the inside,carpet is pulled back,one day i'll get my pedals installed.
    bottle behind the drivers seat
    AN T fitting installed in engine compartment
    firebraid line from feedthrough to t fitting from underneath
    i realize the check valve is on the wrong side of the bottle,i just wanted to keep rainwater out,since it started raining again. i will fix it later
    you're a madman that vaccum bottle thing is like an analog hack hehe.. pretty cool
    what is an analog hack?
    Ichiban's Avatar
    North of You.
    Doesn't the brake booster have to have a vacuum accumulator built in to it?
    ICHIBAN!
    "Now, even more better!"
    Quote Originally Posted by guyhatesmycar
    it stores some,but not very much,i'm also going to use some vaccume actuators inside of the car,and this will also store vaccume for them when the car is off. some future projects.
    Ichiban's Avatar
    North of You.
    The 2g's actually have a vacuum bottle located under the cowl, it's plumbed into the HVAC controls, I never knew it was there until I removed the cowl grille for painting. I'm sure I have a spare, you want it?
    ICHIBAN!
    SEi User knarg's Avatar
    '04 Forester 2.5XT
    Fort Collins, CO
    that's pretty awesome, i must say
    with the one i installed,i doubt i'll need another one,lol,but thanks. this one will probably hold enough vaccume for 5 cars.
    I redid a couple of things and temp hooked up the line for testing
    feedthrough at firewall side
    [IMG]http
    T fitting in brake line engine side
    feedthrough interior side,i was able to get the one i made, to fit properly,after some additional machine work.
    testing for leaks
  1. Plastic Shields Holding Water
    By Shilo in forum 3geez Accords
    Last Post: 07-28-2010, 01:25 AM
  2. charcoal cannister...
    By psdrummin in forum Carburetor Tech
    Last Post: 01-05-2007, 07:35 AM
  3. Battery not holding charge?
    By 88LX-iSedan in forum 3geez Accords
    Last Post: 03-23-2004, 04:19 AM
  4. Replies: 14
    Last Post: 02-27-2004, 12:36 PM
  5. Are the wires holding me back???
    By Chrome_thangs in forum 3geez Accords
    Last Post: 07-21-2002, 01:29 AM
