Im looking into buying some fog lights cause my headlights suck and only light up 2 feet and are weak. I wanna get some good ones and was thinking of blue or yellow fog lights. Can yall help me out? pics would be great.
are they H4 or would i have to change the hole headlight?Originally Posted by LX-incredible
the sealed beam aren't h4 but the price is about the same as an h4 bulb and the installation is identical. you can get them at most any car store like autozone or kragen for $20 each. you can also get autopal h4 conversions with generic h4 bulbs for about $40/pair here: http://cgi.ebay.com/ebaymotors/200mm...07065639QQrdZ1
i have the sealed bean silverstars and they work pretty well imo. no problems seeing at night.
Yes, you will need to change the whole assembly. If you get the sealed beams for $20-$25 so each, they come with reflectors. The bulbs are like the stock ones. Instead of replacing just the bulbs, you replace the whole unit. If you go with the H4 housings, you can replace the bulbs separately. Depending on which bulbs you go with, they will be brighter, but the initial setup will be more.
ok so get silverstar sealed beams, what size? 7 x 4 right?
you need these lights...Autopals
arnt those H4 conversion? If i do the conversion i'll get those, but for now i'll get the sealed beam.Originally Posted by BITESIZE
High & low beam headlamp
H6054
H6054ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H6054XV XtraVision Halogen - The Brighter Light
H6054CB Cool Blue Halogen - The Whiter Light
H6054LL Long Life Halogen Upgrade: Lasts 6x longer
thx a lot man, i'll check those out at walmart or autozone, i saw some silverstar headlamps at walmart i'll see if any of those are there. Those will fit my car? what size should i get incase.Originally Posted by LX-incredible
ok, thx again for the help and thank you everyone else.Originally Posted by LX-incredible
Are these head lights good? They're from GE and they shine brilliant white light.
Are these good fog lights? From navigator comes with harness, instructions, bulbs, hardware to install, and a switch.
Anyone know if these are good or what?
ROFL thos our the same fogs i got
and yes thos lights are alot brighter i had them on my 82
Those fog lights look like mine but mine are Pilot. They are pretty good for the price.
Can anyone tell me if these lights are good?
thxOriginally Posted by LX-incredible
those cool blue sealed beams are good, thats what i used to use, much much much brighter then any other selaed beman i have ever used
i want to find some yellow lens fogs, does anyone know of any?
Hella e-code housings with 8k hids....
Hella E-Codes FTW!!!
nice but i just need bright headlights.Originally Posted by Cheeseburger
