Results 1 to 4 of 4
Thread: 8 volt preamps on a 2-4 volt amp input????
    Washington
    so Ive now got a choise to make. Ive got an eclipse cd8445 and a pioneer deh-p980bt. The eclipse with 8 volts on the preamps and the ppioneer with 5 volts. If I was to plug either of these into a phoenix gold amplifier that took 2 or 4 volts ( cant remember) WHAT WOULD HAPPEN
    2ndGenGuy
    Guest
    Re: 8 volt preamps on a 2-4 volt amp input????
    Well, if your amp can't handle 8 volts, don't hook it up... I would think that the deck should have a way to drop it down to 2 or 4 volts though. Sometimes just turning the Subwoofer Volume down is all it takes. I've never even heard of an 8 volt output. This stuff they're building anymore is so overkill and rediculous.
    Feb 2007
    1989 Accord LX 5spd; 1990 Cadillac STS 4spd auto; 95 Civic 5spd
    Its 'backwards compatible' don't worry about it.
    d-_-b
    Feb 2004
    89 accord lxi
    down by the bay
    yeah, it'll be fine. should have a nice low noise floor, too. just make sure to set the gain on the amp to the lowest setting.
    the only minor disadvantage is that the range of your volume control from the deck will be a little smaller (you'll just hit max volume at a lower setting).
  1. Kinetik HC1400 - 1400 Watt 12 Volt Power Cell Battery
    By nswst8 in forum Interior & Exterior Care
    Last Post: 05-29-2010, 08:47 PM
  2. 12 Volt "big Three" Upgrade
    By nswst8 in forum 3geez Accords
    Last Post: 09-18-2009, 07:04 PM
  3. Volt meter installed
    By russiankid in forum Interior & Exterior Care
    Last Post: 02-08-2007, 11:04 AM
  4. HELP--sony PS2 converting to 12 volt
    By blahblahblah in forum Interior & Exterior Care
    Last Post: 02-24-2006, 04:56 PM
  5. 60,000 Volt Coil !!!
    By 3rdgenlxi in forum Performance
    Last Post: 10-15-2003, 08:11 AM
