Results 1 to 14 of 14
Thread: Blower Motor Problem
    LX User azazel_18_2's Avatar
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    I have an 89 honda accord lxi and have a blower motor problem still. I have replaced the blower motor and resistor. I removed the evaporator and replaced all orings and cleaned the fins out. I turn on the fan and it works but it just barely blows. I put my volt meter on it and it only has like 9V. Oh, I also replaced the diode right before the blower motor. It is driving me nut. A/C blows ice cold but barely blows so it's worthless. I hooked 12V up to the blower motor and it spun like it should then. Any ideas? Anything I can test? Let me know!!!
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Re: Blower Motor Problem
    Maybe a ground wire?
    Where did you get the 12v source?
    I played around with my fans once and completely sealed off the two fans by the doors and left the middle ones so they would blast a lot harder and would also reach the passengers in the back easier.
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    I jumped from the battery. I may replace the switch assembly. Maybe that will help? I don't know I am just a little irritated!
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    and I have checked my grounds.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Test voltage out of the fan switch assembly. Most causes of low blower motor speed is the resistor. (but you replaced it) If it's not the fan switch assembly, then you have high resistance in the wire somewhere or the new resistor is bad.
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    Here is what I have found out. I am only getting 9V to the blower motor. I checked all the way back to the switch. I replaced the switch and still the same thing. I checked voltage at the switch and all it is getting is 9V. Any ideas? I am so tired of the a/c problem.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Must got some voltage drop going on. I'll try to get a print out of the wiring at work, off Mitchell 1 program.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Does anything else seem like it is getting low voltage? It could be a bad connection in the ignition switch
    CARDONE SUCKS.
    Sep 2006
    Tucson, AZ
    The fan switch controls the motor through the negative wire. Test between the positive at the motor and a good ground. If the voltage checks out, check the fan speed switch and its ground. If the voltage is low, check fuses, the ignition switch, and wiring.
    CARDONE SUCKS.
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    must be in my wiring somewhere. I swapped out ignition switches and same old shit. I may rig it until I can find the problem. It is to damn hot not to have a good a/c.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    The diagram I look at today looked similar to that. Might get a DVM & start testing the resistance from point A to point B. Electrical problems are tricky & hard to find. Hard to say without being there. Good luck!
    If you do run a 12 v jumper to it make sure its the right size for the amperage and is fused JIC.
    High should be fully grounded if you look at the schematic. So the 12 v seems to be the problem.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    From my diagram I looked at, there might be a diode in the circuit that could be the problem. It shows it, put don't show where it is at.
    Here is a tool I mess with to look at similar problems with. Has some good testing abilities if worked right. Called a POWER PROBE 2.
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    I ordered and replaced the diode even though mine tested out. It is driving me NUTS.
  1. blower motor stop working
    By import racer in forum EFI Tech
    Last Post: 12-03-2016, 07:30 PM
  2. FS: Blower motor resistor New in box.
    By theJunkman in forum For Sale
    Last Post: 12-29-2010, 05:51 PM
  3. Heater blower motor fuse
    By Oldblueaccord in forum 3geez Accords
    Last Post: 01-21-2010, 08:04 PM
  4. HVAC blower motor
    By wknox in forum 3geez Accords
    Last Post: 01-11-2005, 07:40 AM
  5. May heater blower motor died
    By Bobs89LXi in forum 3geez Accords
    Last Post: 05-23-2002, 06:20 PM
