Thanks for the compliment. All I am saying is it's not always as easy as it seems. I just saw your 1st post on this page (pg 2) and you made it sound like everythng is cheap and easy (Place Racing mounts are not $150). It really sounded like you were going to take the stock harness that came with the new engine (which is all it usualy comes with), plug it into the A20 harness that goes from the engine bay to ECU, and then plug in the new ECU. If that is what you meant, here is what I was trying to say:say there is a wire for the O2 sensor from the new engine which does coincidentally plug into the right pin location of the existing A20 engine bay to ECU harness. But that doesn't mean the wire will go to the right pin for the O2 sensor in the new ECU. Some ECU's have different pin locations for certain sensors compared to other ECU's. This is where you have to do your studying if you are going to do this swap without using a premodified engine harness like the one from Place Racing. But reading what you said afterwards, if this engine swap kit comes with everything you need to fit the B motor in a 3rd gen properly, then you don't have to worry about guessing and custom work since it's all been done for you. Did that make alittle more sense?? (It's 3:30am and I need sleep......)
