Take off old grille to make sure your new speaker is going to fit.
Now using automotive grade masking tape line out the area with tape. Make sure the tape is tight and conforms to all contours of the area.
Using a Sharpie outline the contours. This is a good time to mark your screw holes as well.
This a cheap piece of fiber board I had a couple scrap pieces laying around. It is about 3/8" thick.
Lay the out the masking tape flat as possible the board.
Now trim everything you outlined with the Sharpie. Also drill the screw holes at this time.
Remove the masking tape and sand all edges.
Rap the board with your choice of color fabric.
Make sure speaker with grille fits.
If your satisfied with your work... just install it. Then repeat for the other side.
Sorry I had to post a how-to here, but it won't let me in the how-to section.
Hope you guys find this helpful.
