Results 26 to 50 of 56
Thread: 7/7/07 Led Taillight Modifations
    Idaho
    Re: 7/7/07 Led Taillight Modifations
    Ok, so I got some of the parts in, let the making begin.
    Idaho
    God these pictures don't even show how bright they really are!!! I'm super stoked now. I'm going to save up and build a set for my car's tails.
    I made these superflux led's for my front clear turn signals. My cost is around $8 each!! Ouch!
    Idaho
    I'm going to hook two of them together for the front turn signals. Total of 16 superflux led's! Superbright!
    Idaho
    This gives you an idea how big these will be.
    race12001's Avatar
    Sanford NC
    sweet how do they look during the day
    Dec. 05-Dec. 06
    Idaho
    Quote Originally Posted by race12001
    Bright as hell. These are 5x brighter than the brightest regular leds.
    hey did you get my PM?
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    start on them hatch tails already! The red brake lights always seemed dim to me some nice red leds should look real good behind the lens well behind the red difuser part anyway.
  9. #34
    LXi User DDRaptor's Avatar
    1988 Honda Accord LX
    Bronx, NY
    did you have to solder each indivually. cause those are much bigger than the board leds i've worked with?? also are you planning on including a load equalizer with the sets or does each board come with their on because i did'nt see it.
    thanks and good luck on the project.
    89LX or SE-i(yeah right)
  10. #35
    Idaho
    Quote Originally Posted by DDRaptor
    I did all of the soldering. This is the first time I've used the superflux leds. What is a load equalizer and any other information would appreciated.
  11. #36
    looking good shorty
  12. #37
    DX User pot_of_rice's Avatar
    1989 Honda Accord
    Toronto ON
    Looks real good. Once you got everything set im up for a set!!!
  13. #38
    Idaho
    Quote Originally Posted by pot_of_rice
    I need a set of tails donated before I can start the work.
  14. #39
    Idaho
    Inside the housing with just 8 lumileds. I'll be using these 8 because they fit snug in the housing and won't need to be glue or mounted in.
    I wish you guys could see these in person!!
    Took it dark so you could see the leds.
  15. #40
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Usually a wire-wound resistor that makes up for the reduced draw of the LEDs, which stops them from blinking rapidly.
    CARDONE SUCKS.
  16. #41
    Sep 2006
    Tucson, AZ
    Are those wired in series? How much do they dim with slight voltage changes?
    CARDONE SUCKS.
  17. #42
    Idaho
    They are in a series without any resisters or anything hooked to a 9 volt battery. I don't know anything really about lumileds.
  18. #43
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Here is what I am doing with my front turn signals. I am putting these directly in place of my original bulbs.
    http://www.superbrightleds.com/specs/115x-xLX3.htm
    They are 44 lumens as compared to the high flux led's which convert to 6.25 lumens per unit. These can be purchased for $23 each. They come in white, red and amber and have a viewing angle of 130 degrees.
  19. #44
    Idaho
    ^$23 is too damn expensive for one.
  20. #45
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    One is all you need for a turn signal. They are actually brighter than the original bulb
  21. #46
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Here is the result. I discovered that the wires to the bulb socket had to be reversed because the led bulb expects pos 12 volts at the center contact but Honda wired these with the negative at the center contact.
    Before clearing.
    Cleared but with amber bulb
    New led bulb
    wires reversed
    The result
    turn signals on
    Done
  22. #47
    SEi User ChaseR's Avatar
    Dec 2003
    2004 Acura TSX, 2019 CRV
    Reno, NV
    Subscribed
  23. #48
    BUMP!
    Idaho
    I still have them, i cleaned my pm.
  25. #50
    1989 Honda Accord
    Toronto ON
    just curious....if i donate you a pair would you send them back with the leds? I can send you a pair of the red/whites or my stock ones.
  1. headlight/taillight mod
    By loko84hb in forum 2geez Accords
    Last Post: 08-06-2007, 03:19 PM
  2. Taillight conversion?
    By ETAftermarket in forum Interior & Exterior Care
    Last Post: 12-26-2006, 04:26 PM
  3. How do you like this taillight mod???
    By jteuton in forum Interior & Exterior Care
    Last Post: 01-13-2005, 06:24 PM
  4. taillight ?
    By Frankfurt812 in forum Interior & Exterior Care
    Last Post: 03-29-2004, 05:37 AM
  5. Taillight alignment
    By Stefi-blueLX in forum Interior & Exterior Care
    Last Post: 10-02-2002, 01:52 PM
