Results 1 to 18 of 18
Thread: Another build idea: TTTT
    LXi User DDRaptor's Avatar
    1988 Honda Accord LX
    Bronx, NY
    Twin Turbo Track Terror
    I know someone is gonna say your nuts and why, anyways just read and opine
    A20A3
    -NO A/C
    -NO P/S
    -Remove all the interior except for drivers seat
    -Remove all vents, radio, heater, etc.
    -Lighten Crank Pulley
    -Toga HP Oil/Water Pumps
    -Adjustable Cam Gear
    -Rods+pistons (don't know which)
    -9.1 C/R
    -Custom dual intake manifolds
    -Dual 24mm Throttle Bodies
    -DC sports header
    -2.75 Piping Exhaust system
    -P&P Cylinder Head
    -2 junkyard turbos preferrbly from volvo 850
    -intercooler
    I don't have my parts guide mag infront of me so i know i'm missing something, don't flame cause of course i have no idea where the hell i'm gonna put 2 turbos. but just testing the waters for viability.
    89LX or SE-i(yeah right)
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    Re: Another build idea: TTTT
    usually in a twin turbo setup you have a smaller turbo helping to spool a larger turbo. you probably wouldn't have 2 similarly sized turbos unless you were working on a v6/v8 etc.
    if you want big power you need one BIG turbo.
    also you cannot use a DC sports header with a turbo setup.
    and 2.75" exhaust will be restrictive.
    and 24mm throttle bodies are not large enough, even if there were 4 of them. and what do you mean by dual intake manifolds?
    gutting your accord and rebuilding your motor is a good start, but you definitely need some more planning.
    either way if you are serious and have serious questions there are plenty of people on the board who can help steer you in the right direction.
    SEi User ZackieDarko's Avatar
    you could do a remote mount turbo...two of 'em if you really wanted to no need for an intercooler that way too
    bobafett's Avatar
    Longview, WA
    right.... no need for an intercooler...
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Why bother twin turboing at all?
    Get one turbo set up and running, with a good management solution, then maybe think about trying some sort of screwball twin turbo setup.
    Alex
    edit: gl with all that
    bobafett's Avatar
    Longview, WA
    how many seriously fast supras use twin turbos? oh thats right, most of them convert to single turbos! whoops... twin turbo is a drivability compromise. give up power to have better low end response.
    Oct 2000
    1989 240sx FB,
    Salem, OR
    As for viability, honestly, forget about it.
    Going from a carbed 3g, to some sort of beastly drag car takes a lot of time and money.
    And again, you haven't listed any management, which will probably wind up doubling the cost of your build.
    Alex
    bobafett's Avatar
    Longview, WA
    yeah i agree. management on a true monster is not cheap. even a low buck standalone system will run you $2k minimum to control fuel and spark. some setups are closer to $4k all said and done.
    i know how much $$ i have dropped and how much further I have to go, and I see cars like johnny o, and dont even WANT to know what he has invested into the car. lol
    but i maintain, if you really want to build a badass monster, and have the means and the dedication to do it, just ask the smart questions and we can help guide you.
    89T's Avatar
    Apr 2004
    this may help. it is a bit complicated though.
    borgwarner turbochargers.
    http://www.turbos.bwauto.com/products/r2s.aspx
    as far as huge hp goes i will have to agree a big single turbo.
    un-motivated!
    3GR
    Nov 2002
    Ridin Dirty in New York
    it wouldnt be cheap but you could do it. If you ran 2x IHI RHB5s they would support over 400hp or so for the pair plus prolly be fully boosted by 2750 rpm or so. They are tiny pea shooter turbos... The big thing is this, a single bigger turbo would be more efficient and less work to fab and install and have a better result. So sure, you can twin turbo an A20 but i dont see why youd want to. Id say 3" exhaust at least for any kind of real power boosted. Plus a dc sports header would be worthless for boost, and remote mounted turbo systems arent all theyre cracked up to be. For the best results you should do an underhood turbo and turbo manifold instead of a remote mount system.
    nice way to spend 3k.
    Bronx, NY
    lol, lots of resposes quickly, i was wrong on the header i did'nt have my book with me but i'm thinking of twin smaller turbos 7-8psi, with 2 smaller TB's i was just thinking about. besides i would'nt be using my carbed accord for this it would be another 88-89 lxi or se-i coupe.
    Bronx, NY
    i was thinking it would end up around 6k including all the suspension, tranny upgrades, roll cage, etc.
    Quote Originally Posted by DDRaptor
    Engine and turbo setup alone would prob be 6K, if you did it right.
    bobafett's Avatar
    Longview, WA
    yep definitely. you would be lucky to squeeze in management under that $6k mark. tranny upgrades are probably at least 1k-2k depending on what you are doing, suspension if you are starting from scratch should run 1k-3k depending on what you are doing, and roll cage should be 500-1.5k.
    However if you do a lot of the work yourself and get good deals you could easily be under this mark.
    snoopyloopy's Avatar
    Killa Cali
    best way to make big power is single turbo per bank of cylinders. so a20a3-tt would be novel, but if power is what you're going for, rebuild the internals and then slap a hell of a monster on there and run 30 psi. that should get you closer to your goals.
    Nov 2002
    plan on spending like at least 5-8k to do a serious build the right way. Stuff isnt cheap
    yeah i would just run a turbo with very very good management on a stock engine till it wears our and then go and spend the big bucks on the internals.
  1. want to build up my car
    By cavalierboy02 in forum Forced Induction
    Last Post: 07-02-2007, 03:02 PM
  2. please help me build a box
    By buttaz1 in forum Interior & Exterior Care
    Last Post: 04-20-2007, 09:01 PM
  3. Possible ENgine build idea
    By DDRaptor in forum Carburetor Tech
    Last Post: 12-31-2006, 02:14 PM
  4. an idea for my build...
    By gfrg88 in forum Forced Induction
    Last Post: 11-18-2006, 10:37 PM
  5. good idea? bad idea? P/S
    By HondaManDan in forum 3geez Accords
    Last Post: 08-03-2002, 06:44 PM
