getting an amp soon, where is the best place that you have found to mount or put it? im hesitant to put it under seat becasue of the easy breakintoability of my car, and probably hard to remove the seat.
real 3geez http://www.3g-generation.com
i sold the honda. now working on a car with little bit more potential, an 88 supra. i still stop by occasionally.
Just bolt her to the back of your back seat and run all your wires from there :pimp:
1988 Honda Accord LX-i
R.I.P. Died on 7/2/03......
yup thats where mine is ...mounted on the back of the back seat
yep, same here... and if your amp has endcaps you can run all wires under the carpet on the back of the seat and just have em all be invisible looks cool having just an amp sittin there
thats what i have planned to, it's just the best spot
Fast and cheap won't be reliable.
Cheap and reliable won't be fast.
And fast and reliable won't be cheap.
"It takes the dough to go."
yep either under the front seat or mounted on the back of the back seat are the best options. If you are worried about someone breaking into your car then under the front seat would be the most worry free place.
-Aaron-
i just mounted mine to my sub box easy to get at lol
on the roof? in ur lap? in ur house? in the trunk? yah, the trunk sounds good! if you are powerin subs, the closer the amp and the shorter the wire, the power power will get to the subs!
Travis
