ok well im so stumped any help would be great!! so here is the problem car idles high when not moving, when im driving the car i can put in neutral let off the clutch and it idle fine at jus above 1000 when i come to a complet stop idle goes up to 1500 and sits there. when i got this car had a lumpy idle, new water pump and a bleed fixed that ran beautiful for a few days then this idle problem started.?????
i have blead and re-blead the system a few times cause the lumpy idle comes back every once in a while, goes away after bleeding evry time, but will come back after a day or 2???
