prologue: sorry for the wall of text. its a longer story than i though. i put "=" at the particularly confusing parts...
i think i have a real problem now. about a month ago i found my hatch was a bit reluctant to start, and soon after that i noticed it sort of shuddering, or hesitating a tiny bit, when holding or accelerating slightly between 2000-2500 rpm. one day when i parked it, it smelt strongly of fuel so when i returned i had a look under the bonnet, and found the little acceleration pump that squirts extra fuel into the main barrel was leaking from its base. i took the carb out, cleaned it up a bit, re-sealed the pump with high temp silicone sealant and tapped back in a little brass hose spigot that had worked loose. it didnt leak anymore and the smell was gone but the slight cough and the reluctant starting continued.
i put that down to the cold damp tasmanian weather, and adjusted the ignition timing [rotated the distributor] slightly forward and back of its original position. advancing the spark a tiny bit made the hesitation almost completely disappear, but made the idle more uneven with regular popping and more vibration. i decided to put it back to its original position and just wait for warmer weather.
then the idle got really unstable and uneven, barely managing to stay above 800rpm, and just recently it wouldnt idle at all without choke. the first i noticed was when i rounded a corner, pushed the choke all the way in as usual, and then had the engine die completely when i stopped at the next intersection. i tried to re-start it but it just kept bogging and dying as soon as i released the throttle, so i pulled the choke back out and then it idled at about 1000rpm, though still quite rough. i didnt know what to make of this as a few seconds before it had been running happilly, not miss-firing and with no loss of power or anything, and continued to run happilly from 1500rpm up [as usual] as long as it was in gear. i put the choke back in and continued to run fine, untill i stopped again, and it died again. it was fully warmed up by this stage but still needed the choke to idle at all.
at this point the problem seemed to be that:
-starting was tedious
-it would hesitate a bit around 2000rpm
-it was idling unsteadilly at about 1000rpm
-it would stall immediately without any choke
on the way home however i found it was shuddering noticibly while cruising on the flat and coasting down hills [but not really under acceleration] and when i stopped the idle would bog down and the engine would shudder alarmingly and almost stall. this was at a busy round-about where it was sort of stop-and-go, and every time i released the accelerator and disengaged the clutch it would splutter. but it moved off normally through the round-about and up a hill, no sign of sluggishness or lurching or anything.
i was pretty annoyed at this so i stopped in the garage [still running] and popped the bonnet, loosened the distributor and moved it about. the idle was really rough and sickly, and advancing the spark raised it a little bit but didnt make it any less unsteady or poppy. i had run out of advance adjustment so i put it back where it had been and it died [wheezing] before i could even do the bolt up
i took the air cleaner off, re-started it and managed to get hold of the throttle directly before it could stall again, and kept a finger on the tab to keep it chugging. i found something weird: the choke butterfly has a secondary, very light spring that allowed me to flip it completely open without moving the button. this caused extra spluttering but with additional throttle it would keep going, whereas popping the button in would cause it to die immediately.
= what does the choke button do, besides move the cable and operate the butterfly?
today, it wont idle at all. it often takes a few attempts to get it to chugg off the starter and onto its own power. it will rev reasonably normally but bogs if i let it fall anywhere near 1000 rpm, and pops and splutters badly at 2000rpm. releasing the throttle is instant death, and moving the choke in either direction away from the first stop is also instant death.
i checked and cleaned all the ignition gaps and contacts and checked for vacuum leaks but didnt find anything very interesting.
= however i did find that, at TDC on the flywheel, the marks on the camshaft pulley were sitting a few teeth from horizontal. could this have slipped? i re-set it but it made diddly-squat difference to the situation [yes i changed the valve timing substantially and it had no effect ]
= i took the rocker cover off and found nothing sus, except this:
weird white residue clinging with the oil on the underside of the filler cap, and:
same residue, seemingly collecting in the vent baffles. it hasnt made it to the air cleaner barrel though.
"OH NOES BLOWN HEAD GASKET " is what i thought, but i didnt find oil in the coolant, or the residue anywhere else around the valvetrain etc. or on the spark plugs.
so i said "rrraaarrgh!" and decided to stop wasting my battery charge and post it all for the experts. halp!
