Results 1 to 8 of 8
Thread: headlights still won't open
    bridgewater.NS Canada
    Exclamation headlights still won't open
    well i changed the switch in the dash and they still won't open or close.is there a relay for these somewhere,this has got me stumped.guess i can change the motors even thouthe guy i got the car from said he already did that. any ideas guys.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: headlights still won't open
    On the passenger side, in the engine bay, between the headlight housing and the radiator. There is two of them.
    CARDONE SUCKS.
    Quote Originally Posted by LX-incredible
    do they both have to do with the headlight motors.
    Sep 2006
    Tucson, AZ
    Yes.
    CARDONE SUCKS.
    check to see if there is power going to your relays, and to your switches first.
    That should help you eliminate the problem
    if neither headlight goes up or down and you have checked the fuses, try swapping the electronic control module under the dash. it's a small gray box and it will have stanley retractable control, on it. does the headlight warning in the information center come on,when you turn the switch for the lights and they don't pop up? if it doesn't there is eithier a fuse blown somewhere or the module is bad. i doubt you have a motor problem if neither light goes up and down.
    DX User DaveTheAve's Avatar
    Jul 2007
    1988 Honda Accord LX-i
    Magnolia, KY
    I'm also having a headlight issue and have checked the fuses; however, I do not have the ability to replace the switch. I was told removing the switch makes them pop-up which they do not do when I disconnect the switch. Is there a course of action you recommend for me?
    Thank you,
    David Branco (Neoelite Web Consultant)
    http://www.NeoeliteUSA.com/
    "I would love to change the world, but they won't give me the source code"
    Quote Originally Posted by DaveTheAve
    what do you need a switch? pm me and i'll send you one i have about half a dozen of them around here. talking about the dash mount switch now. do you need the lights up for now? if you do,pull the fuses for both lights in the under hood fuse box,then turn the knob on each light motor,it's under the rubber cover, until he lights are up.
  1. is open header ok
    By salgmz in forum EFI Tech
    Last Post: 01-05-2008, 01:39 PM
  2. headlights wont open or close
    By import racer in forum 3geez Accords
    Last Post: 07-24-2007, 07:44 PM
  3. How to Open Taillights
    By dalinxz in forum Interior & Exterior Care
    Last Post: 05-13-2007, 06:29 PM
  4. Choke won't open 100%.. HELP?
    By fotosoup in forum Carburetor Tech
    Last Post: 01-20-2007, 01:52 PM
  5. Open Air EGR?
    By FoX in forum 3geez Accords
    Last Post: 03-16-2005, 11:31 AM
