Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Thread: something draining battery overnight
    Re: something draining battery overnight
    what part of your gauges dont go?
    89T's Avatar
    Apr 2004
    do you have an aftermarket stereo? or stock?
    did you install anything before you started having the problem?
    un-motivated!
    3GR
    carotman's Avatar
    Montreal South Shore
    Use an amp meter to test how much of a draw you have.
    That's the best solution. The only thing that should have a draw is the ECU/Clock fuse.
    I need these parts!
    89T's Avatar
    Apr 2004
    what i am getting at is if there is a aftermarket stereo they may have shorted the insterment cluster lights. or wired the stereo wrong. i have seen people use the dimmer and dash light wires for a ground. (those wires show a ground when the lights are off.)
    i also agree with corotman on the ohm meter senerio.
    un-motivated!
    3GR
    Quote Originally Posted by wohdog
    the tach & some of those lights, a couple of the red lights go though
    LXi User Steve_Si's Avatar
    1986 Honda Accord 2.0Si
    Christchurch, New Zealand
    Check the RCD behind the interior fuse box. It's made of unobtainium, should be easy to spot.
    RCD? unobatainium?
  8. #33
    well the battery hasnt gone flat lately, and half the dashboard accessories dont go, nor do the wipers or turn signals, but the battery doesnt go flat must be some dodgy wiring in the dash somewhere
  9. #34
    LXi User -$MOKIN-'s Avatar
    Apr 2006
    1989 HONDA ACCORD LXI
    does your ac fan come onwhen its not supposed to. mine did it for a couple weeks. had a broke line to my ac controller
  10. #35
    nope , havnt got any A/C or heater controls in that car
  11. #36
    DX User bubba g's Avatar
    Jul 2007
    89' LXi
    Like carrotman said, Use an ampmeter then start pulling fuses till it goes away. Don't forget to disconnect the alternator while you are doing the test. I have seen alternators drain batteries when they get an internal short.
    My other car gets about 6 miles to the gallon.
    69' Chevelle SS396
    89' LXi
    ASE Master tech
  12. #37
    carotman's Avatar
    Do you have a capacitor? My battery would go dead because I installed a capacitor for my amps.
    I need these parts!
  13. #38
    nope, havnt installed anything electrical that would drain the battery (except the alarm) but even with it unplugged it still drained. i cant remember which dash harness i was using, but i might of been using a cut up one in there (half assed start for climate control conversion), cant really think of anything else it would be. though it isnt really a problem anymore now that i got another car that actually saved the battery
  1. Problem w/ Brake Lights (draining the battery)
    By OptimusPrimeSr in forum Classic Honda Community Chat
    Last Post: 10-01-2008, 02:36 PM
  2. Battery Draining After A Week... May have found the problem!
    By azazel_18_2 in forum 3geez Accords
    Last Post: 10-06-2007, 05:03 PM
  3. Battery draining overnight
    By tanstaafl in forum 3geez Accords
    Last Post: 10-27-2006, 02:43 AM
  4. Draining my battery??????
    By luis1578 in forum 3geez Accords
    Last Post: 09-05-2006, 10:00 AM
  5. Replies: 6
    Last Post: 02-11-2005, 02:06 PM
