I've got this `83 accord that burned some valves. So I pulled the head and sent it out for a valve job. After install I got 180 pounds compression. After running it for 3 or 4 months I have aquired a knocking in number 1 piston. I'm guessing it's a rod bearing? Right? So, what am I looking at to replace the rod bearings? When I had the head off, there was very very little ridge on the top of the cylinders. So, with 180 pounds comp. I don't really want to disturb the upper end. When I pull the pan, what will I find? should I replace the oil pump? if the crank is not scored, can I just put in a set of stock sized bearings? or do i need to do the plastic gauge thing? I'm an old chevy guy and not really sure what i'm going to find. Thanks for any advice you can give me.
Steve
