That's strange, it should run for longer than that. You can test the fans by running them direct. First remove your under-hood fuse box cover:
The second relay from the left is the main cooling fan relay, the round metal relay to the right is the auxiliary relay.
Cut two wires 6-8" long and strip both ends. To test the main cooling fan insert each wire in the two contacts closest to the passenger fender like this:
For the hell of it you can also test the auxiliary fan. Insert the two wires in the contacts closest to the firewall like this:
*Make sure you don't let the wires touch anything, battery voltage is present.
*Check your contacts before connecting the wires.
When the two wires are touched together in the main fan relay slot, the main fan should come on and run for as long as you hold them together. When you touch the auxiliary wires together, the auxiliary fan will come on. If either of the fans don't come on, or run sporadically, the motors need to be replaced/rebuilt
Hope this helps...good luck.
