you'll run richer if you plug off ABC from the AJC (Air Jet Controller) on the carb.
I'm only sure that C is for the secondary Air Correction, till I can get my carb in front of me... From looking at my pictures though I would say that A is for Primary. and B for Slow mix... but then if it's not slow mix then I dunno... maybe idle or an Aux primary
If you're a nut like me and play around, hooking one of the ABC lines from the carb back to a carb venturi vacuum port under the fuel line you'll siphon gas from the Air Correction Jets.
