Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 90
Thread: Wish Me Luck I'm doing My Smog Test Today
  1. #51
    Re: Wish Me Luck I'm doing My Smog Test Today
    Quote Originally Posted by CcordLevel2 View Post
    When i lived in texas i had a fiero gt with a s**t engine. i knew it wouldn't pass a sniff test so i put a bottle of "smog pass" in the tank. when they did the test it came out 0.001 or something like that (really low). Then again, the dual exhaust was rusted through on both sides between the muffler and tips. maybe thats what did it.
    I'm a little sceptical as to if that stuff really works, but maybe you can have someone send you some if its illegal in cali.
    I saw that stuff at one of the local parts store the other day , I figure it will be my last shot if all else fails
  2. #52
    SEi User ChaseR's Avatar
    Dec 2003
    89 Accord LXi Coupe, 07 Civic Si Coupe, 08 Civic hybrid
    Slidell, LA
    Yeah from what I know that stuff will make your car run like pure butt with that shit in the tank. So you will want to burn it off quickly when you are done.
  3. #53
    Quote Originally Posted by shepherd79 View Post
    how old is your distributor?
    You may have to rebuild it with new springs.
    How long has it been since you did your tune up?
    How big is your spark plug gap?
    What kind coil do you have?
    What kind wires do you have?
    Very Good ... things to double check before you go swapping computer controls. Your car is reading good at road speed and seem reading Hi CO just off idle and before good air flow..So ignition and timing curve check would right on the money in that range.
    O2 sensors generally , if they are sho nuff bad will make it run rich all the time, but if is just tired and starting to go bad it may take a fraction of a second more to read to the computer in time to make mix adjustments.
    That is one of the reasons I suggested bumping the timing (ign) up even if you dont leave it that way, just for the test.
  4. #54
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Lots of good points mentioned, got to have timing & spark of coarse. That IAT sensor plays a good part in ECU input & injector pulse. I googled this link up why I mentioned it. Check it out. Click on the blue link in the sentence too. (yeah, that is diesel engine, but it works the same principal in NA engines)
    http://www.dodgeram.org/tech/dsl/sensors/IAT/clean.htm
  5. #55
    shepherd79's Avatar
    Falling Waters, WV USA
    1) Dist. is original to the car
    2) Tune-Up done when I rebuilt the engine March 07
    3) Plug Gap .032
    4) Coil= MSD Blaster II
    5) wires = NGK
    I just replaced the 02 sensors and had a friends shop run a check on it for me and the C0 levels went down a bit but not much.
    I'm going to replace my MAP sensor with one that I had in the A/T vac.box and see if that helps and going to swap the ecu back to the A/T one that I had before when the car was auto and see if that does anything.
    One thing I have that is not stock to the car is the injectors, they are off a 90 accord, how much of a difference would that be?
    Oh well if the other stuff I mentioned above doesnt help any I'l go for the cat. which I suspect is the reason for the high C0. I took it off the donor car, it looked alright but I had my doubts before installing it but I had no choice and funds to replace it with a new one.
    Since you have MSD blaster 2 coil you can make spark plug gap a little bigger. .04 or .045 that will increase amount of spark and time it will stay on. try that.
    as far as injectors, 4G accord has same injectors are we do. it is the same flow rate. so you shouldn't have any problems with it.
    Cat, well high flow cat may be your problem at this point. I don't know why people buy into the idea that cats are very restrictive. Stock honda one is very restrictive but aftermarket ones are not that bad.
    this is what I had to get to pass MD emissions. http://www.car-sound.com/02product/d...irectfit=22623
    I got it on ebay for $70 shipped to my door.
    so search the ebay for that part number. It worked great, all my numbers were very low.
  6. #56
    does anyone know if I should leave the timing alone at the stock setting or adjust it before I take it in today for retesting
  7. #57
    Jul 2007
    1986 Honda Accord DX 3DR
    umm yea well u shouldnt mess with the timing bc its part of hte test also...but have u check ur fuel pressure regulator...bc it is vacuum controled on a FI car. if the car is running at a low RPM it will have less fuel pressure and if the RPM is high it will allow more fuel. so if tat is leaking or the diaphram is ruin. then it will always have a rich mixture. which is like 30 to 40 psi of fuel in ur rail. jsut letting you kno. besides tat causes of high CO can be stuff like CAT, O2 sensor, leaky injector...etc... its a rich problem for sure.or u can have a leak right b4 the o2 sensor which will give it a reading tat ur car needs more fuel... tats all i can think of for now...GL man
  8. #58
    Ok here's what is going on so far
    Most of you know that the engine has been fully rebuilt on the car and she is still running rich and wont pass smog.
    So far aside from the rebuild I have replaced the following:
    engine was block was bored out to .020
    stock camshaft with GE Cam gear set at zero
    4th gen Injectors (new Bosch units)
    New oxygen sensors
    New Magnaflow Cat.
    MSD Coil
    fuel pressure regulator was replaced 2years ago when I bought the car, I'm thinking thats the problem.
    soullessknight suggested the pressure regulator,
    HELP!!!
    I'm at the end of my rope and I need valid suggestions on getting this fixed or I'm going to SELL THE CAR
  9. #59
    ... or I'm going to SELL THE CAR
  10. #60
    I'm frustrated
  11. #61
    DX User Hoy_LDT's Avatar
    Sep 2007
    1986/3drHatch/LXI
    Milpitas CA!
    i believe its isopropyl alcohol that you add into your tank so that you can run engine hotter, with lower emisions...its not good for a daily thing since it will OVER heat your engine quite fast and maybe even blow something....but i THINK this is what could help you...im not sure ill ask my friends at school tmrw so dont jump to anything....
    also i know that hydrogen peroxide works as well...but you would have to put it threw a distillation process *if you where to get it over the counter* and at that u can only get 2-4% max from each bottle you buy, and a big warning of explosion(s)....
    but again ill ask my buds at school
    Just Get Er DONE!
    brake caliper and zip-ties what do they have in common???=GettoGeddy...
  12. #62
    Quote Originally Posted by Hoy_LDT View Post
    i believe its isopropyl alcohol that you add into your tank so that you can run engine hotter, with lower emisions...its not good for a daily thing since it will OVER heat your engine quite fast and maybe even blow something....but i believe this is what could help you...im not sure ill ask my friends at school tmrw so dont jump to anything....
    Cool keep me posted
  13. #63
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Best not run iso or hydrogen peroxide in your car.
    How the plastic fuel lines will handle it is abit on the iffy side.
    the american market might not have them but my jdm si duz , and i'm not to keen on a petrol fire in the passenger compartment.
  14. #64
    dam bro that sucks that you cant get it to pass dont give up tho!
  15. #65
    Pico don't give up, it running rich isn't the end of the world.
  16. #66
    New oxygen sensors
    New Magnaflow Cat.
    MSD Coil
    HELP!!!
    cant u pay someone to pass it?
    what ever you do dont give up on the 3gee
  17. #67
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    What did it fail on?
  18. #68
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    It worked on my SE-i. I failed on excess hydrocarbon so I bought the CRC stuff and ran an entire tank of gas through it. Just before I went to the test I put a full tank of gas in without this additive in it. It passed with low numbers. I later changed my cat and it has passed ever since.
  19. #69
    Quote Originally Posted by Blkblurr View Post
    failed on CO level
    Readings were
    15 mph Max .078 / Avg .010 / Meas 1.53
    25 mph Max .066 / Avg .009 / Meas 1.64
  20. #70
    Sep 2007
    1986/3drHatch/LXI
    Milpitas CA!
    my friend that knows about this wasnt there at school today...so your gonna have to wait till i talk to him on monday sorry...
    Just Get Er DONE!
  21. #71
    no problem
  22. #72
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    High CO levels is most likely your cat. Is your engine running cool? Thermostat temp lower than OEM?
  23. #73
    OE temp on the thermostat and I got it from the dealer, I replaced the cat 2 weeks ago.
    Engine temp is right below the half way point
  24. #74
    yeah i have herd of the thermostat making the car run rich. aparently getting a higher temp one makes your car run better. my mate has the same problem in his civic, it runs rich and sometimes misses and pisses round when its cold. he even swapped engines and the other one does the same thing its like its the cars fault its running rich haha. i have no idea why cars do it. even mine runs a bit on the rich side
  25. #75
    better put those old injectors in before you put that in your tank, Iso alchohol reaks havoc on your electronic injectors and injector circuit to the ECM
    Do they check your timing at teh smog station? if not see my first couple of posts on this thread
    I thought you maybe knew somebody that had an old CO meter and tailpipe sniffer to see what is up so you can check it good before the test ??? this equipment has been around for years although it is not as sufisticaked .lol as the new stuff
    edit.. Hey I just thought of something else too that could drive you nuts.. evap system. does your gas cap swoossh when you open it? lol.. sometimes the fuel pickup screen and lines going to the tank from the filler neck, charcoal cansiter.. can get obstructed and cause a lot of fumes to build up in the system that is powered by ... engine vacuum.. so it can back up to the point that is sucks fumes into the mixture at the vacuum source
  1. Failed Smog test
    By michigan_accord in forum 3geez Accords
    Last Post: 07-02-2007, 08:05 PM
  2. failed a smog test...
    By snoopyloopy in forum 3geez Accords
    Last Post: 05-11-2007, 11:37 PM
  3. smog test what do i need to pass
    By SHURIK in forum 3geez Accords
    Last Post: 04-15-2005, 02:16 PM
  4. Installing new engine today, wish me luck
    By Tref_LXI in forum General Engine Swaps
    Last Post: 03-22-2003, 11:41 PM
  5. Failed Smog Check (Emissions Test)
    By jay in forum Classic Honda Community Chat
    Last Post: 09-22-2002, 01:51 PM
