Page 1 of 4 1234 LastLast
Results 1 to 25 of 90
Thread: Wish Me Luck I'm doing My Smog Test Today
    I'm getting my smog test done today at a test only station, My friend knows the guy and he says the guy will look the other way when it comes to my modifications.
    Since the engine has been rebuilt and has less than 5000 miles on it everything should go nice and smooth.
    Anyway Wish me luck
    Re: Wish Me Luck I'm doing My Smog Test Today
    you'll pass, this is the picomobile we're talking about
    I would never pass, they would send me to detention. I would have to top off the tank with 103 blue so the fumes would get them buzzed while I grab the clipboard. I love the way that stuff smells..
    good luck bro!
    I'm on my way
    weee....make sure to take some pics.
    Just Got Back From Smog Test
    FAILED
    She's running a little rich, I'm going to replace my 02 sensors and maybe the cat, and have them retest it again
    that sucks Roger. i know my car is running rich since my exhuast pops a lil bit. try some seafoam next time....im not sure if it would help but it helped my bucket dx pass.
    I thought about seafoam, but the engine is all rebuilt so I think the problem is going to be cat, or 02's
    How would sea foam help a brand new engine pass smog? Most likely it is the O2 sensor(s) or the cat. I doubt it has anything to do with the engine itself. I think it is time for a High flow cat
    Did you run it up to tempurature before it was smogged? Maybe it needed a little more warm up time on the highway at about 90 mph to heat that cat up too.
    Quote Originally Posted by Oldblueaccord
    I drove for almost an hour before taking her in.
    I going to exchange my 02's at work and have another friend run the test on his machine to see if that helped
    This time, try driving the car around for 1-2hours doing over 3k rpms.
    i think it makes the cat run a bit hotter
    doh, hope its no more than the 02 sensors
    Yea but why put crap through a new engine? Just run it hard....
    snoopyloopy's Avatar
    Killa Cali
    aww, by how much? i usually run seafoam in a tank of premium when i go get mine tested, just for the heck of it.
    because gas is not cheap? i ran my car for 40min hard...like 80mph and with seafoam and it passed the sniffer but not visual since a hose was a lil busted up. and my dx has oil leaks and the timing is off
    I have an oil leak, and i remember mine passed without a problem. I remember we just drove straight from home to the shop, and it passed right away.
    Well IMO, i would rather spend some extra gas than put crap into a new engine. Plus gas is $2.50 over here
    Killa Cali
    now that's bs. i still think the point of a smog test is lost when you can pass the sniffer but fail a visual. the air quality will suck whether or not the hoses are connected, but as long as it blows clean, it shouldn't matter. i think the carb needs to get off their high horses and realize that. </rant>
    Quote Originally Posted by snoopyloopy
    failed on CO level
    Readings were
    15 mph Max .078 / Avg .010 / Meas 1.53
    25 mph Max .066 / Avg .009 / Meas 1.64
    Can someone tell me what the hell it means
    Luckily the test only station was a friend of a friend and all he did was run it to see if it would pass or not. I should of mention that earlier that the results did not get sent to DMV
    failed on CO level
    Readings were
    try cleaning TB good with toothbrush n rinse good, use 02 safe spray...bump ign timing up much as it can stand W/o ping...retry
    not positive but it looks like a just off idle rich then it goes cleaner/yes slow 02 would do the same thjng too
    Quote Originally Posted by roodoo2
    I'm hoping thats the problem, every single engine part that didnt go to the machine shop to be rebuilt was disassembled and cleaned of all carbon deposits.
    I'm happy at least the tech. passed the visual part of the test.
    There should be no problem if I install a hi flow cat. (not a test pipe) is there?
    I don't see why it would cause any problems, a good cat will do what is suppose to do. I have a fairly new cat, so i am happy
  1. Failed Smog test
    By michigan_accord in forum 3geez Accords
    Last Post: 07-02-2007, 08:05 PM
  2. failed a smog test...
    By snoopyloopy in forum 3geez Accords
    Last Post: 05-11-2007, 11:37 PM
  3. smog test what do i need to pass
    By SHURIK in forum 3geez Accords
    Last Post: 04-15-2005, 02:16 PM
  4. Installing new engine today, wish me luck
    By Tref_LXI in forum General Engine Swaps
    Last Post: 03-22-2003, 11:41 PM
  5. Failed Smog Check (Emissions Test)
    By jay in forum Classic Honda Community Chat
    Last Post: 09-22-2002, 01:51 PM
