Results 1 to 8 of 8
Thread: Differential oil seal replacement
    Hi all,
    I have an '88 LX auto sedan that has started leaking badly from the oil seal where the driver's side axle mates to the differential; this happened when I changed out the driveshaft (NAPA rebuilt replacement). The factory manual says this seal should be replaced from the inside of the diff, but I was wondering if anyone had replaced this without taking the diff apart.
    Thanks for any help!
    Hyong
    Re: Differential oil seal replacement
    Are you sure the little ring on the axle isn't at fault? Those rings can leak too.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    What ring? You should be able to replace the seals from the outside. You need a seal puller and something flat to drive them in with.
    CARDONE SUCKS.
    Quote Originally Posted by LX-incredible
    It is like a clip but looks like a ring at the end of the axle that goes into the tranny. It snaps into the tranny. I read that those can cause leaks.
    Sep 2006
    Tucson, AZ
    Well yes, if the axle came out, it would leak. I dont think that's the problem here.
    This is what a seal puller looks like:
    there are other types as well.
    CARDONE SUCKS.
    Cool,
    Thanks for the help LXi!
    Russiankid, I was thinking of that myself. The clip is a Honda part (pulled off the one that came with the NAPA axle). I had to pull the axle recently to replace the alternator, and I replaced the clip again but the leak continued.
    I'll have to find the oil seal puller -- it looks like it will make the job a lot easier.
    Hyong
    You can pry the seal out with a screwdriver Its a fairly easy one. I think i used a 2x4 to knock it back in the case. Grease it a little and you should be set. Dont forget to top off the case with 10w30 oil or honda gear lube.
    Sep 2006
    Tucson, AZ
    Quote Originally Posted by Oldblueaccord
    Even better. He has an auto though, so use Honda ATF.
    CARDONE SUCKS.
  1. Valve Seal Replacement?
    By 1981.EK1 in forum 1geez Tech & Performance
    Last Post: 05-29-2012, 06:26 AM
  2. [Engine & Transmission] Camshaft Seal Replacement
    By mushroom_toy in forum How To
    Last Post: 11-28-2007, 04:33 PM
  3. Oil pan seal replacement
    By russiankid in forum 3geez Accords
    Last Post: 10-29-2007, 07:17 AM
  4. Valve seal replacement.
    By Chrome_thangs in forum 3geez Accords
    Last Post: 01-26-2003, 04:52 PM
  5. Shift rod seal replacement
    By AZmike in forum 3geez Accords
    Last Post: 10-22-2002, 05:19 PM
