Results 1 to 21 of 21
Thread: headgasket
    Exclamation headgasket
    hey y'all just wonder how hard is it to do a head gasket? is there a how to anywhere i searched but could not find anything it kept timing out
    Idaho
    Re: headgasket
    This would be hard for you. Don't do it.
    LX User evil88accordLX's Avatar
    Jul 2007
    gold 88 accord lx
    NWA (not the rap group)
    Re: headgasket
    well you would have to remove the head, so you would have to drain the coolant, relieve the fuel pressure, remove the valve cover, intake and exhaust manifolds, top half of timing cover, timing belt, and the head itself. you would need to clean the mating surfaces, replace all the gaskets you removed, and reset the timing. if you are carbed, there are more hoses to deal with than FI. it can be done in a day if you know what you are doing, and if you dont really, just take your time and give yourself like a week so you dont get overwhelmed.
    Re: headgasket
    if i do it i want to get another head from like a junkyard and have it rebuilt with new valves and shit
    Re: headgasket
    Do a compression test before you do that to see if it is worth it.
    Re: headgasket
    yeah i need to get a better tester
    89T's Avatar
    Apr 2004
    Re: headgasket
    you dont need to take all the hoses off. just remove the black box off the firewall and unplug the harness.(there are acouple that you do need to disconnect (I.E.charcoal canister, master cylender.))
    as for the intake and exhaust manifolds you can leave them on the head.
    set your timming to tdc before you remove anything.(make sure the arrow or "up" on the cam gear is inline with the valve cover bolts.)mark a rib on the t-belt then slide it off the gear carefully(put a bungee cord on it to keep the belt tight on the crank.) and make sure it is in the same position when you reinstall it. as for swaping everything over to another head, it's easier to do it on a work bench.
    un-motivated!
    3GR
    Re: headgasket
    what i plan to do is:
    get a used head from the junk yard take it to a shop have them rebuld it and install new valves and shit so its redy to be installed also since im there i want to replace the water pump and timing belt since my pump has a bad barring and my timing belt is due
    Re: headgasket
    for one you should pick up a hynes book for the accord helped me out alot for the first time i did a head gasket, has all the tourqe numbers and such your gona need. also how much money are you dumping in this car? things add up quick when ou say oh ima just do this and that while im at it, so just think before you start spending, if your trying to get the car runnig to sell then spend bare min. have fun if you do this
    snoopyloopy's Avatar
    Killa Cali
    Re: headgasket
    yeah, i'm gonna change the hg on my eclipse soon, i'll let you know how it goes. sure as hell beats the ~$1100 the dealer quoted me.
    Re: headgasket
    Quote Originally Posted by snoopyloopy View Post
    yeah i called around out here thay told me $3500 i told them to fuck off il do it myself and hung up lol
    Jul 2007
    gold 88 accord lx
    Re: headgasket
    Quote Originally Posted by 89turbo'ed View Post
    i just feel that is easier to get the head out without all that extra stuff connected to it. but if he is new to this and has enough brawn, yeah leave it connected. but if he wants to rebuild a head, it all has to come off anyhow. sometimes its just a bitch to get the head itself off, so the less crap attached to it the better i think.
    Re: headgasket
    i would pull it all off at once, then pull it apart with it separated out of the engine
    89T's Avatar
    Apr 2004
    Re: headgasket
    yea it is alot easier to do it this way!
    it should only take about a half hour to pull it all at once.
    for a head gasket all you need to do is unbolt and tip it back, clean, drop a new gasket and rebolt.
    un-motivated!
    3GR
    DX User Kemikals's Avatar
    Aug 2007
    1988/accord/lx-i Hatchback
    Carrollton, Virginia
    Re: headgasket
    Just remember, every bolt you take out, put it back exactly where you found it
    If you're not breaking parts, you're not making enough power!
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: headgasket
    Quote Originally Posted by Kemikals View Post
    That & CAH, make sure you label every hose with masking tap to where it goes. That will help in the re-install. When you take the head gasket off, be carefull not to knick the head with the razor knife to deep. It is real important to clean it good. Hopefully it's not warped, cause you'll need a strait-edge to check it. Get the metal gasket by Fel-pro. Use a torque wrench to torque to specifications & in proper senquence. (now lets see it happen)
    PIC for head & intake taken off.
    Re: headgasket
    thanks everyone the project is on hold right now untel winter or untel mine blows wich ever comes 1st lol
    Killa Cali
    Re: headgasket
    arp headstuds ftw while you're at it...
    Re: headgasket
    come on its CAH....and shit ....i was thinking about some studs but im not going turbo....the stock ones should hold just fine.
    Re: headgasket
    im thinking more like oem replacement lol
    Re: headgasket
    yeah, in all experiences, i'd recommend replacing the studs. whether it be head studs, intake or exhaust manifold. like like to break off after you've retorqued them. so i never make that mistake again. the honda ones should be fine. i had to order mine though for my exhaust manifold. so why do you think you need to replace the head gasket?
  1. Re-using headgasket.
    By mushroom_toy in forum Performance
    Last Post: 04-25-2010, 05:36 PM
  2. WTB: headgasket
    By military mase in forum Wanted
    Last Post: 05-17-2009, 12:27 PM
  3. headgasket???
    By military mase in forum Performance
    Last Post: 09-26-2005, 08:44 AM
  4. Headgasket
    By 88EXi in forum Classic Honda Community Chat
    Last Post: 09-14-2003, 06:34 PM
  5. A20 headgasket pic
    By POS carb in forum General Engine Swaps
    Last Post: 10-30-2002, 12:51 PM
