Results 1 to 12 of 12
Thread: Won't start, fuel pump won't kick on
    DX User Kemikals's Avatar
    Aug 2007
    1988/accord/lx-i Hatchback
    Carrollton, Virginia
    I've done some reading and i'm thinking the problem is the main relay, just want to run it by you guys to see what you think. Last night me and cousin replaced 4 wheel studs and took the car out for a short drive, came back and parked it in front of the garage. Went to turn it back on and nothing. checked to see if i was getting spark and getting plenty, just did a tune up last saturday on it. Tried it again today after work and still a no go. We took the main relay out and checked it, it "looks" fine but I read that the main relay is like 2 relays in one, one controlling the fuel pump and the main one.
    If you're not breaking parts, you're not making enough power!
    LX User twofast4u's Avatar
    Jul 2005
    1989 honda accord
    Toronto, ontario
    Re: Won't start, fuel pump won't kick on
    I've had this exact problem...first i thought it was the main relay. I swapped it and nothing...then i thought fuel pump...swapped and nothing still...then the computer because the LED wasnt flashing. Bu then again how could it be the computer if everything else worked. I was getting spark too. Although i found out that wen i put in the new motor there was a ground that was loose...tightened it up and it ran first time...Although im sure its one of the things i stated above..I hope it helps!!!
    If you guys wanna check out my car, here's the site:
    http://www.cardomain.com/ride/778695
    Aug 2007
    Thanks, i'll look around for some loose grounds, that can cause the fuel pump not to kick on at all?
    Jul 2005
    1989 honda accord
    Toronto, ontario
    yea its possible..i learned the hard way...grounds play a MAJOR roll on these cars!
    Do a search here on Main relay or a google search for the same. There s a good website on how to jump the relays out to see if that is the problem.
    Aug 2007
    Another thing that happend I forgot to mention is a fuse was blown under the hood, the ecu/clock one. I replaced it and had expected to hear it fire right up but still no go. I've checked all other fuses and nothing else is blown, could this have fried something else?
    DX User dlr1989's Avatar
    Mar 2007
    Originial Owner of a 1989 Accord LXI 4 Dr
    Hastings, Nebraska
    The question is, what caused the fuse to blow? I don't have a wiring diagram in front of me to look at right now, but I recommend looking at the one in the service manual and seeing what that fuse feeds and start testing those devices. ECU maybe. ECU wiring problem maybe.
    Quote Originally Posted by Kemikals View Post
    They can have my Accord when they pry the steering wheel from my cold dead fingers.
    77 accord hatch 79 - 85
    82 accord LX hatch 85 - 87
    89 accord LXI sedan 89 - 09
    09 accord EX-L V6 w/Navi sedan 08 -
    My garage
    Aug 2007
    Fixed the damn thing well not fixed but diagnosed. it's that damn main relay... i had it hanging down outta dash still "kinda forcefully relocated it " so gave it a few good back hands and it fired right up lol thanks for all info guys.
    haha i remember my old cars main relay used to do that, i kicked the dash and it clicked on good stuff, now pull it apart and resolder all the joins so it wont die agaiN
    Aug 2007
    Already done it lol pulling another one tommorrow at pick n pull just as an "in case stuff happens" part, along with a new driver side window switch, head, and other miscilaneous items i can find.
    http://techauto.tripod.com/mainrelay.htm
    fix and bypass options
    LX User GTRSkyline43's Avatar
    Jul 2007
    1987 Honda Accord Lx-i(Hatch)
    Hayward, Bay Area 510
    had problems with my fuel pump as well...toke out the whole fuel pump assembly form the trunk and wired it up to a batteries to see if there was a leak(tested with water) next thing you know water start shooting out all over so i just replaced the pump it self...started it up and it worked...try checking your fuel filter as well to see if you get pressure
  1. Fuel Assembly , Pump , & Fuel System Location
    By A20A1 in forum Carburetor Tech
    Last Post: 05-10-2016, 01:27 AM
  2. Fuel Filter? Fuel pump?
    By Bass Man in forum 3geez Accords
    Last Post: 05-19-2008, 03:38 AM
  3. Replies: 2
    Last Post: 12-15-2006, 07:25 AM
  4. 89 lxi efi will only start when you pump the gas
    By storozuk60 in forum EFI Tech
    Last Post: 08-09-2006, 02:45 PM
  5. Replies: 10
    Last Post: 05-03-2005, 11:00 PM
