removing the ac belt shouldn't change much, but if i remove the power steering belt, will the power steering fluid in the rack n pinion system cause very hard steering? should i drain the power steering fluid if i don't plan on using it, to ease turning?
(setting the car up for a turbo build)
maybe i don't need to remove the power steering?
i don't use the AC, there's something in the freon that makes me sneeze like a mofo.... but power steering would be cool to keep if it will fit with a turbo setup...
.: t
