Results 1 to 7 of 7
Thread: where to find rod bearings?
    May 2006
    I've got this `83 accord. needs rod bearings. I thought I found some, but they say that the one I need for the second journal is dis-continued. it's an A3 or yellow, any ideas? Also, I was going to install a oil pump, but the say that it has been discontinued too. Are the remans or aftermarket any good? I'm also looking for the correct rod cap torque. I've come up with 21 and 23 foot pounds. What do you say?
    Thanks in advance.
    Steve
    Idaho
    Re: where to find rod bearings?
    Honda Dealer FTW.
    May 2006
    thanks for the quick response. I went to my honda dealer. He said they buy through Vintage Parts Inc., I found them on the internet and ordered. Now the have wrote back and said that one of the bearings has been discontinued. So, where do I go from there? Any ideas?
    Thanks
    Steve
    Idaho
    Call JC Whitney.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Rockauto.com has rod & main bearings for the 1.8, but not many parts for the 1.6.
    2ndGenGuy
    Guest
    I have had luck ordering oversize bearings for the EK1 at AutoZone and Shucks. I'm not sure if they do the color coded bearing sizes or not, but if you need to get your crank turned, you can just order one standard set for all of your bearings. Just an idea if you can't find the color-coded ones.
    SEi User
    81 HB LX, 84 HB S, 89 LX-i Coupe
    Indianapolis, IN
    Not the dealer for sure. CarQuest or NAPA usually have some of the harder to find parts. The machine shop I took my head to seemed to have some hookups for sure. They weren't any special performance type import shop... just an independent machine shop that's been around forever. Maybe try that, too. Rockauto.com is a good place, too. Good luck man.
  1. rod and bearings
    By zigzag in forum 3geez Accords
    Last Post: 01-18-2009, 08:30 PM
  2. IH8 bearings!
    By rfiks in forum 3geez Accords
    Last Post: 11-15-2008, 10:27 AM
  3. hub bearings
    By dXsquared in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-17-2002, 03:45 AM
  4. How-to get Bearings out from Hub
    By SiR in forum 3geez Accords
    Last Post: 10-12-2002, 09:16 AM
  5. Replies: 2
    Last Post: 09-30-2002, 03:29 PM
