Results 1 to 22 of 22
Thread: adaptor plate
    LXi User coope's Avatar
    Sep 2006
    89 accord lxi efi
    mississippi
    adaptor plate
    enybody kno where i can get an adaptor plate i want run lsd or just a b16 tranny or 1.8 type r trans since i need a new clutch enyway while i got it down might as well do it big
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    CARDONE SUCKS.
    Re: adaptor plate
    our tranny are somewhat strong.....im getting the whole thing done....integra gears, lightenfly, new excedy clutch, short shifter and tranny rebuilt....it should be puting civics on my rear view mirror.
    89T's Avatar
    Apr 2004
    Re: adaptor plate
    this will give you an idea of what you need to do. start at post 252
    https://www.3geez.com/forum/showthrea...312#post816312
    un-motivated!
    3GR
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: adaptor plate
    thanx i just want to run lsd i'll look into it
    89T's Avatar
    Apr 2004
    Re: adaptor plate
    Re: adaptor plate
    Quote Originally Posted by coope View Post
    89 turboed just did an lsd mod....im thinking about it since its only 300 bucks and im going to re do my tranny but i dont want to blow it up.
    SEi User ZackieDarko's Avatar
    Re: adaptor plate
    yeah well a Phantom Grip LSD sucks...i wouldnt even call it a real LSD
    the OBX LSD's for the B16's can be modified for the 1st gen integras
    i would assume if it will fit in that tranny it will fit in ours since they are virtually identical on the inside
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: adaptor plate
    so what would be better phaton grip or adaptor plate well what would be cheaper to run enyway cause i think my tranny is about to give and i want to run shorter gears cause im going for an na build i have an extra tranny im gonna get it this winter and slap some intergra gears in that suka and going with the clutchnet stage 1 and what year is those integras we use? how does that sound!!!!
    Re: adaptor plate
    Quote Originally Posted by ZackieDarko View Post
    yeah i been talking around. with other members and they say some of them just make the gears wear out faster and when it goes it takes the whole tranny out. but some look like they had some good results....
    lol i just googled OBX LSD and some of them say they suck also....plus our trannys are cheap if you are a dedicated racer or gear head you will have more than 1 so you can switch it out. like i said im seriously thinking about it. 300 bucks cant be that bad.
    89T's Avatar
    Apr 2004
    Re: adaptor plate
    ok! so whats a real lsd? whitch one do you have in you'r car? where are you'r dyno numbers, time slips, does you'r car even run?
    i am starting to take this as a personal attack, so quit the clowning...
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: adaptor plate
    how is ur setup working? is ur gears wearing out fast
    Re: adaptor plate
    Quote Originally Posted by 89turbo'ed View Post
    take it as what ever the hell you want dude
    honda axles are a dime a dozen
    if you are gonna take what i said as a "personal attack" then you got bigger issues then a broken axle and a shit lsd
    Re: adaptor plate
    i'm pretty sure he made the adapter plate cause the a20 ones kept breaking, though i doubt any of us would make enough power to destroy one lol
    89T's Avatar
    Apr 2004
    Re: adaptor plate
    you'r right axles are a dime a dozen and that's why i laughed when i broke one and it has since been replaced.
    as far as the pg goes it is only as good as you install it.
    you have to reserface the gears so if you do a shit job doing that you will end up with a fucked up tranny.
    now as far as the obx lsd i can't say if it is shit or not because i have never owned one.
    so if you are not trying to get personal then squash it.
    Re: adaptor plate
    ive seen guys with the obx and you do get what you pay for but its not bad at all really. Im very curious about modding it to fit a 1g teg though. Does anybody have any more info about it?
    Re: adaptor plate
    yeah he must of been pushing like 400-500 hp. even after an engine rebuild and turbo for street use you can only make like 200-300whp.
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    Re: adaptor plate
    its true that a pg will probably kill your diff faster than without, but there are other factors. do you use the high tension springs or the lower tension springs. like 89'turbod said there are factors during installation as well.
    plus its either this or $800-$1200 for a quaife lsd plus a b-series tranny plus an adapter plus new axles. so for the $2k plus that it would cost otherwise, i think a $250 (even if it IS diff killing) PG LSD is a fine option.
    Re: adaptor plate
    the pg is an option but isnt as good as a true lsd. As mentioned the installation is critical. Nobody would say but id bet jason budd had closer to 600+ hp with his a20 and the engine has been bulletproof. Either way i dont think youre gonna have too much problems with the tranny untill the 10 sec range
    Dec 2006
    Re: adaptor plate
    Screw Phantom Grip. Send your stock diff, along with like $750, to OPM Motorsport. The PG unit is just a half-assed copy of their modification anyway. They rebuild your differential, along with installing the actual clutches behind the spiders, with the spring blocks in between. The blocks press the spiders against the clutches, but there's litle space between them so wear is minimized. Just like a real clutch pack LSD.
    Re: adaptor plate
    Quote Originally Posted by Secondaries View Post
    too bad only people with lots of money or lots of power will want to do that....i still think the phantom grip is not a bad deal at 300 bucks plus even with bolt ons our cars are not that fast....fastest NA is like high 14 secs.
    SEi User obd0driver's Avatar
    Feb 2012
    89/accord/lxi
    Re: adaptor plate
    Just updating old post. Heres a link with details. https://www.facebook.com/groups/3gee...5611320491415/
    Sent from my SM-N950U using Tapatalk
  1. Number plate/ registration plate mounting
    By Australian 86 in forum Interior & Exterior Care
    Last Post: 06-05-2011, 05:13 AM
  2. proper oil pressure fitting adaptor,
    By lostforawhile in forum Performance
    Last Post: 09-05-2009, 01:25 PM
  3. TW: Distributor adaptor plate GB?
    By Secondaries in forum Restoration & Custom Fabrication
    Last Post: 02-03-2008, 01:10 PM
  4. oil filter adaptor?
    By lostforawhile in forum Restoration & Custom Fabrication
    Last Post: 01-20-2007, 11:08 PM
  5. carb civic intake adaptor for sale
    By Mantis88LX in forum Trading Post
    Last Post: 05-12-2003, 09:19 PM
