Results 1 to 8 of 8
Thread: B20A Engine Restore Part Numbers
    DX User Scorpion-Sting's Avatar
    May 2004
    Exclamation B20A Engine Restore Part Numbers
    What up 3 geeyers,
    i had these part numbers that i stripped off a JDM part number catalogue...
    these parts all concern stock engine restoring, hope some one finds it usefull
    Serial Number Item Name Quantity
    061A1-PK1-500 Gasket Kit A 1
    061B1-PK1-000 Gasket Kit B 1
    13013-PK1-003 Ring 050 1
    14400-PK1-003 Timing Belt 1
    15100-PK1-660 Oil Pump 1
    14510-PK1-004 Timing Belt Bearing 1
    14711-PH3-000 Valve Intake 8
    14721-PH3-000 Valve Exhaust 8
    14111-PH3-010 Intake Cam 1
    14121-PH2-000 Exhaust Cam 1
    13103-PK1-004 Piston 4 Pieces a Set I guess
    22810-PF5-008 Clutch Bearing 1
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Re: B20A Engine Restore Part Numbers
    Quote Originally Posted by Scorpion-Sting View Post
    What up 3 geeyers,
    Wow thanks for taking the time to post that info. Do you own a B20a?? U should come and post more often
    pk1 sounds like b20a5 to me. the ph3 is the jdm b20a...but just saying just in case cause the head and intake gasket between b20a and b20a5 and 100% different. i cd be wrong.. if i am wrong disregard this post
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    I have a ecu from a B20a5 and its a Pk2. Not sure what Pk1 is
    May 2004
    As i remember the control for my B20A2 is a PJO
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    which one do you have? The black top r the gold top?
    yeah true b20a5 might be pk2 the gold top b20a in the 2g ludes over here are pj5
    May 2004
    Black Top
  1. B20A Manual Transmission Part numbers (B2K5 and F2K5)
    By carotman in forum JDM B18A / B20A Swap Tech
    Last Post: 05-24-2011, 09:51 PM
  2. Engine Restore
    Last Post: 03-21-2006, 06:47 PM
  3. B20a Part numbers
    By TWOLOUDNPROUD in forum General Engine Swaps
    Last Post: 10-04-2005, 11:22 PM
  4. A few B20A part numbers
    Last Post: 02-02-2004, 07:30 PM
  5. jdm part numbers please
    By b20a86lude in forum General Engine Swaps
    Last Post: 01-29-2004, 03:56 PM
