Page 6 of 6 FirstFirst ... 23456
Results 126 to 136 of 136
Thread: SZfiftyfour's 2G Accord Restoration
  1. #126
    Re: SZfiftyfour's 2G Accord Restoration
    Nice. How do you plan on making the outlets for the heater hose and stuff?
    LXi User SZfiftyfour's Avatar
    '82 Accord DX Sdn
    Ocala, FL.
    Probably end up with something like this: Dorman 56399 Water Pump Inlet Tube | eBay
    Which they carry at most parts places, then just drill the holes and have someone weld them in place. Need to find the right size tho
  3. #128
    Could you braze or solder those tubes on? The metal is pretty thin, and I don't think the water pump is under a ton of pressure.
  4. #129
    '82 Accord DX Sdn
    Ocala, FL.
    Yeah that was suggested by my dad also. A certified grease monkey for decades, so I'm inclined to believe ya'll. I'm looking for durability overall, just worried solder would crack due to vibration/hot-cold cycle.
  5. #130
    Yeah, that's a good point. I don't know much about it, but I think lead-free solder is prone to cracking (main relay anybody?). Not sure if you can buy regular leaded solder or not, or if it would really even matter.
  6. #131
    DX User Samwise's Avatar
    Aug 2011
    '89 DX Sedan (RIP), Very Special '87 LX-i Hatch
    You'll be fine as long as the solder you pick has a high enough melting point. Pb90Sn10 is commonly used in car cooling systems.
    Proud new owner of Catalyst's hatchback
  7. #132
    '82 Accord DX Sdn
    Ocala, FL.
    Thumbs up Re: SZfiftyfour's 2G Accord Restoration
    So this is ready, finally (:.
    Also currently working on getting the head cleaned up. New valves/seals going in soon.
  8. #133
    Quote Originally Posted by Samwise View Post
    Awesome to know! Thanks for the information.
    Quote Originally Posted by SZfiftyfour View Post
    That looks awesome!! Nice work on the new part. You should build and sell them
  9. #134
    '82 Accord DX Sdn
    Ocala, FL.
    Thanks man, but don't see that happening lol. It's pretty much a hack job just to have something that works, and no easy way to do it, but it's heavy duty
    and it'll work for a while. The welds are nice tho.. I didn't do that part x).
  10. #135
    LX User JJ'sAccord's Avatar
    Dec 2016
    1989 honda accord LXI
    South Carolina
    great job man! i bought the inlet pipe a year or two ago brand new. i kept my old one to grab the dimensions off of it and i plan to make me a couple of back up (i have a feeling they will stop making these soon if they haven't already stopped making them) of course mine was a 89 LXI so it looked a little different but same purpose!
    good job again SZfiftyfour.
  11. #136
    '82 Accord DX Sdn
    Ocala, FL.
    Quote Originally Posted by JJ'sAccord View Post
    Thanks, yeah they will probably discontinue them eventually, which is the reason I had to make this one.
    Good luck with the project. In my case, the main issue was keeping the cost down, I'm no fabricator, I don't have the tools or the experience
    so I used what tools I had (apart from buying a few little things) and took the cheap/easy way out. Which is why I say hack-job. Like as-in, using the 2x4 pipe-bending
    method 'vs' buying a tube bender for $80. Or, using a cutting wheel on a cut-out tool (not safe) because that's what I had. And If you notice, the heater tubes
    aren't nippled they're just regular tubing slightly larger than the stock heater tubes, which will suffice. Since I couldn't find a heater tube the right size without
    buying another whole coolant tube assembly to cut up. Also, unless you can make them you'll need the in/out fittings from another water pump inlet tube, which
    automatically puts the running-total at 100% original part cost. I don't even want to think what it would cost to have someone make one from scratch. So anyway,
    I was trying to stay as close to original part cost as possible. I would suggest buying one more at least, to hold onto for later if needed,
    only because it costs more to make them. Or just take good care of the cooling system, like I should've done with my car back in the day.
  1. Stezie's - 1988 Accord 2.0i 16v - OEM Restoration
    By stezie in forum Classic Honda Pics & Videos
    Last Post: 04-24-2019, 01:28 AM
  2. Heat gun restoration
    By nswst8 in forum Interior & Exterior Care
    Last Post: 12-27-2009, 09:35 PM
  3. 1977 Accord Restoration
    By carver in forum 1geez Accords
    Last Post: 01-31-2009, 06:31 AM
  4. Seeking Seat Cover Fabric--Mauve Red--For 1986 Accord LXi Restoration
    By Raphael in forum Interior & Exterior Care
    Last Post: 04-25-2007, 01:07 PM
  5. Suspension Restoration
    By 86-accord-lxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-28-2006, 01:11 PM
