I've been putting in axles today and when it came time to tighten the lower ball joint back up, I put the joint into the lower arm and started to tighten the nut and about 3/4 of the way it tightens up and the whole joint starts to spin. It was late, so I stopped work but as it is the nut won't lock up or back off the joint spindle. This is the first time I've had this problem. Does anyone know what's up? Do I just need to hammer the lower arm up on the joint spindle to keep it from turning? Or is this a busted joint?
