Results 1 to 9 of 9
Thread: PGM-Fi Light on Interm. and Code 01
    Alright guys after driving a while, the 86's PGM-FI light will come on for a while, then eventually go off. I'm also thworing a code 01. I just wanted to see what you guys thought before I pick up a o2 sensor. Oh also what did you guys get in terms of 02 sensors? Denso, or Bosch or other>? Another question is when I go around a left hand turn my car cuts out a little, and I have some fuel loss, when my fuel is under a quarter./ Any ideas?
    DX User bubba g's Avatar
    Jul 2007
    89' LXi
    Re: PGM-Fi Light on Interm. and Code 01
    I haven't had to buy an o2 sensor but I would say don't buy it from autozone. If you could elaborate on your other problems we may be able to help more. Explain "fuel loss".
    My other car gets about 6 miles to the gallon.
    69' Chevelle SS396
    89' LXi
    ASE Master tech
    LXi User DDRaptor's Avatar
    1988 Honda Accord LX
    Bronx, NY
    actually I'm getting the same thing but i have a carb but hwen i turn left i get the same problem if i try to power out of the turn.
    89LX or SE-i(yeah right)
    Quote Originally Posted by DDRaptor View Post
    your problem is your float heights too low and the fuel goes to one side of the bowl when u corner and the jets dnt get ne fuel (had that issue back in the day aswell)
    when it comes to oxygen sensors im not an expert
    and i have no idea what would make your car cut out a little when cornering, mine only does that when its just about out of fuel. maybe u have a large dent in ur fuel tank that ur gauge is reading wrong and ur actually nearly out of gas (i do it all the time)
    Well code 01 is gone, it was in fact the 02 sensor, but i still have the gass loss around left turns problem. This only happens when Im pretty low on fuel.
    Jul 2007
    89' LXi
    It sounds like the the fuel is sloshing away from the pickup. your pump and pickup is on the drivers side of the tank. Your sender is on the other side. When you turn left that would move the fuel away from the pickup.
    69' Chevelle SS396
    89' LXi
    ASE Master tech
    Already knew that. Was just wanting to know if anyone elses car did it.
    DX User Kemikals's Avatar
    Aug 2007
    1988/accord/lx-i Hatchback
    Carrollton, Virginia
    Did you happen to take off that stock air system that came with the car? if so that vaccume line that came off of it will throw that pgm thing after a while intermidently.
    If you're not breaking parts, you're not making enough power!
    Quote Originally Posted by Kemikals View Post
    It happened way before the removal of the stock box. It should be remedied by the 02 sensor, as it has not came on yet. I guess I'll see after longer driving.
  1. PGM FI light Trouble Code 1
    By Honda1987 in forum 3geez Accords
    Last Post: 08-08-2009, 12:16 PM
  2. PGMFI light, code 7, TPS
    By dwillms in forum 3geez Accords
    Last Post: 07-28-2004, 02:10 AM
  3. Engine light but no ecu code?
    By FreaQ in forum 3geez Accords
    Last Post: 10-15-2003, 08:25 PM
  4. Code 6 but no Check Eng Light??
    By Dizzo7693 in forum 3geez Accords
    Last Post: 05-17-2003, 10:43 AM
  5. Code 12.. but no light. Something wrong?
    By jagojon3 in forum 3geez Accords
    Last Post: 05-09-2003, 06:08 PM
