Results 1 to 25 of 29
Thread: Radius Arm Bushings
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Radius Arm Bushings
    getting ready to replace these bad boys with their prothane brothers....shop manual = no help... anybody got a clue how to replace these suckers???
    '89 SE-i Coupe
    Awaiting Garage
    LX User xvok's Avatar
    83 accord honda hatch
    olympia WA
    Re: Radius Arm Bushings
    done this to and rx-7 b4 kinda a pita but baicscley take apart have penatrating oil in a spray can ready and the get some punchs un bolt dowse the bushing in penatrating oil and try to punch it out. for the new ones get some grese put it around the outside eges and the use a vice to push them in reinstal the parts don't forget to torque down bolts to spec and there you go
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Remove the nut on the front end of the strut rod, break loose the back-up nut and then remove the two bolts on the control arm. Installation is reverse of removal. Tighten the back nuts against each other, then 32 ft/lbs for the end nut. You will likely need to check the alignment afterwards, as the position of the nuts determines how far forward the wheel sits...
    CARDONE SUCKS.
    2drSE-i's Avatar
    Oklahoma City
    i didnt think it would be too difficult. the only thing that really threw me off is the metal frame piece (crossmember? got no clue) that it goes in to.
    '89 SE-i Coupe
    Awaiting Garage
    Sep 2006
    Tucson, AZ
    You can leave the crossmember in place. Try to center the wheel in the well before tightening the nuts. I eyeballed it, and had them check alignment afterwards. It wound up not needing an adjustment, but a good idea to check. Torque the two bolts the hold the radius rod to the control arm to 40 ft/lbs.
    CARDONE SUCKS.
    cygnus x-1's Avatar
    Chicago area
    They really only effect caster. The bolts that go into the lower control arm are at and akward angle it may take some extensions to get at them.
    2drSE-i's Avatar
    Oklahoma City
    ya ive done a control arm before. Thanks guys!
    '89 SE-i Coupe
    Awaiting Garage
    2drSE-i's Avatar
    Oklahoma City
    so i feel really silly lol...looked in my haynes manual today and its in there....very detailed directions. So if anyone has questions consult the haynes manual...which actually helped for once.
    '89 SE-i Coupe
    Awaiting Garage
    Sep 2006
    Tucson, AZ
    The Haynes manual is great for that straight forward stuff like that... and the wiring diagrams, but they can keep the rest. They say you need to pull the axle to get to the alt on LX-i models!
    CARDONE SUCKS.
    2drSE-i's Avatar
    Oklahoma City
    you really do...if your replacing it. I had to when i replaced mine, my shop did too the last time...well the charged me for it anyway lol.
    '89 SE-i Coupe
    Awaiting Garage
    Sep 2006
    Tucson, AZ
    No, you don't. That's what pisses me off with chiltons and haynes. They either have you remove more parts than necessary, leave out parts that need to be removed, or not even have the part listed. I only use them for torque specs and wiring diagrams now.
    CARDONE SUCKS.
    2drSE-i's Avatar
    Oklahoma City
    well even the torque specs are a little off. Do you have a shop manual? if not id suggest you download one haha. Even the shop manual said to pull the axle...huh howd u do it then?
    '89 SE-i Coupe
    Awaiting Garage
    Sep 2006
    Tucson, AZ
    I have one. Remove the air cleaner box and it comes out through the top.
    CARDONE SUCKS.
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    I'm just going to try and tighten mine down for now see if that helps. as for chiltons it says 30ftlb on the trans fill hole i cant possibly see that as necessary.
    Sep 2006
    Tucson, AZ
    Quote Originally Posted by Demon1024 View Post
    What? The nut on the front of the radius arm? If it's loose, chances are the bushings are gone and tightening it won't help...
    CARDONE SUCKS.
    2drSE-i's Avatar
    Oklahoma City
    ya i was lost on what he was talking about anyway...
    '89 SE-i Coupe
    Awaiting Garage
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    What are the part numbers for those bushings?
    2drSE-i's Avatar
    Oklahoma City
    Prothane PN: 8-1201-BL
    the BL just means black, they may come in red too, but really what difference does it make you cant see them anyway. When they get to you they will probably say Civic/CRX strut rod bushing, same difference
    '89 SE-i Coupe
    Awaiting Garage
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    What has help me when putting new bushings on the strut rod, was to either count or mark the threads with a paint marker on the back side. Where the rod goes through the frame. It'll keep the caster pretty much where it was at. If you get one side out of wack, more than likely your car will pull to one side.
    2drSE-i's Avatar
    Oklahoma City
    it shows them doing that in the haynes manual actually.
    '89 SE-i Coupe
    Awaiting Garage
    dude at least 1hp for every red part on your car (+5 for red Rs)
    Bglad420's Avatar
    Apr 2005
    90 ED7 Si
    Bellingham WA
    I ordered the reds, so all my bushings will be red.
    2drSE-i's Avatar
    Oklahoma City
    Quote Originally Posted by Bglad420 View Post
    haha but like i said, you wont be able to see these ones. I must say though, i sand blasted my LCA's and painted them black, they look bad-ass with my red bushings in them.
    '89 SE-i Coupe
    Awaiting Garage
    where did you guys buy the bushings....my front end needs some bushings after its been lowered so its more harsh on the suspension.
  1. Radius rod polyurethane bushings
    By nswst8 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-09-2010, 10:21 AM
  2. Radius Rod Question
    By squire366 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-07-2010, 07:49 PM
  3. radius rod
    By GTRSkyline43 in forum 3geez Accords
    Last Post: 12-11-2008, 06:40 PM
  4. OPM motorsports radius rod bushings
    By 89lxihb 00lude in forum Performance
    Last Post: 09-28-2004, 03:09 PM
  5. performance radius rob bushings post old site please
    Last Post: 09-15-2002, 01:19 PM
