Results 1 to 25 of 31
Thread: Help with my Build
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Post Help with my Build
    Alright guys, im in the hardcore research portion of my project, here are my plans.
    Individual Throttle Bodies: Honda CBR FI TB's, using their TPS sensors. I will use an a20 intake manifold, chop it up and use only the flange, straight runners and velocity stacks after the TBs. Heres my questions on this: Should i use the CBR Fuel rail with this? Will it fit? Do the CBR TPS Sensors match the same voltage as our TPS Sensors?
    Semi-hardcore N/A Build
    Headwork: similar to rjudgey's, larger valves, skimmed .5mm, mild cam, upgraded valve springs (researching that as well)
    Bottom End: Skimmed 1mm, Diamond Racing custom pisons machined to work with B-series titanium rods. Comp ratio on this whole build is not to exceed 10.5:1.
    Other than that, like i said im still doing heavy research, this is still at least a year away. As for management, OBD-1. Ill be using a 92-93 Accord Distributor, external coil. Ill have a bracket made for it to fit right. Here is the real question. I want to use Crome or Hondata s300 for tuning. I know almost no1 has run aftermarket tuning, mostly because i dont think there are any decent basemaps for us. Can anyone help me out, point me in the right direction?
    '89 SE-i Coupe
    Awaiting Garage
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Re: Help with my Build
    Most tps volages register at .5v closed throttle and 4.5v wide open. Just test the sensors and adjust acordingly until closed is at .5v and full open at 4.5 volts .
    as far as basemap I would think the closest would be from a sohc 16v non-vtec civic timing. fuel would be a difernt story all together if your going itb's.
    good luck with this project and what kinda time frae you giving yourself?
    cygnus x-1's Avatar
    Chicago area
    Sounds like a fun build. If you went with Megasquirt I could help you but I know nothing of any other EM systems.
    C|
    2drSE-i's Avatar
    Oklahoma City
    a long ass time. As for TPS sensors, i did a little investigating into Crome and it has internal adjustment so you can use any tps sensor. d16 nonvtec i think would be close. I got to looking at how Crome works and apparently you can use datalogging and make adjustments based on readings. I think if i did this step by step it would be best. First, OBD-1 with the ECU that everyone else is using for their swap (i cant remember what it is...) and get it running, make a boatload of adjustments to make it run damnnear perfect, and then swap on the ITBs, and get that running. When i get into my career (hopefully 9 months from now) im buying a new car, and this one will be my weekend driver.
    '89 SE-i Coupe
    Awaiting Garage
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    I'm building a b20a and using toyota 4age 20 valve quad throttles which would prob be the ones that i'd recommend to most 2 liter engine builds.
    depending on the engine spec they come up to 46 or 47 mm .
    Use a modified (of course) manifold for your engine and the toyota 4agze injectors or what everelse you want to use and should be an inlet set up
    good to flow 250 horses.
    And if you can afford it a microtech,motec,autronic or link ecu.
    These computers are all real good. autronic comps run the two fastest 4 and 6 cylinder 4 wheel drive drag cars in the world.
    2drSE-i's Avatar
    Oklahoma City
    CBR throttles are 48mm i believe, and arent as hard to come by. As for injectors, i will either be running 280cfm prelude injectors, or 450 cfm dsm injectors. I dont know crap about those ecus tho
    '89 SE-i Coupe
    Awaiting Garage
    cool i didnt see this thread till today....sounds like a fun lil project im also getting mine done lets hope by next year after April since i want to smog with my stock engine.
    i have similar plans...mini NA motor....nothing over 10.5 compression since i want to keep adding regular pump gas in it.
    guaynabo89's Avatar
    FL
    only bad thing about those toyota itb's is they use side feed injectors. so if anything happens to those its gonna cost ou more for replacements.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    I'm gathering parts for a similar build minus the ITBs. It will be interesting to see what you go with.
    CARDONE SUCKS.
    2drSE-i's Avatar
    Oklahoma City
    what is our stock compression? isnt it 9.5??
    '89 SE-i Coupe
    Awaiting Garage
    Sep 2006
    Tucson, AZ
    Yes.
    CARDONE SUCKS.
    Your going to use the factory accord fuel rail. Make sure to get the proper tuning software, because those ITB's can be a real pain in the ass to tune. Hit me up if you need someone to build those ITB's, I know a shop that could get the job done.
    2drSE-i's Avatar
    Oklahoma City
    yea crome has full ITB support. im more than likely just gonna drop the money and buy Crome Pro. i remember you telling me about that shop last time i was at your house.
    '89 SE-i Coupe
    Awaiting Garage
    9.3 to be exact
    2drSE-i's Avatar
    Oklahoma City
    close enough lol. Seems interesting to me that they went so low with such strong internals, but thats ok i guess haha
    '89 SE-i Coupe
    Awaiting Garage
    Sep 2006
    Tucson, AZ
    9.3 to be exact
    He's right. I wonder where I pulled 9.5 out of.
    CARDONE SUCKS.
    2drSE-i's Avatar
    Oklahoma City
    Quote Originally Posted by LX-incredible View Post
    my ass, same place i pulled it out of
    '89 SE-i Coupe
    Awaiting Garage
    yup yup....i wonder what kind of compression we would get with b18 pistons. i would like to get at 10.3-10.5 compresion...with a .30 overbore.
    2drSE-i's Avatar
    Oklahoma City
    thats my plans. but id rather just get custom made pistons, larger wristpins so i can use titanium b series rods.
    '89 SE-i Coupe
    Awaiting Garage
    2drSE-i's Avatar
    Oklahoma City
    damn dp...
    '89 SE-i Coupe
    Awaiting Garage
    yeah if you do...lets see if we can do a group buy....at least me and you.
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    I think you mean just forged rods. In any event, an all motor a20 probably won't make more than 200whp. Stock rods would probably be fine at the power levels you'll see. I put eagle rods in my 240. Cheap at ~$400 and supposed to hold up to 600-800hp.
    I think the thing to realize is that n/a power costs REAL money, especially if you want reliability sprinkled in with it. Rebello in CA builds n/a Ka24e single cam motors for racecars that can put outl 250-300hp n/a (with carbs even haha), but the motors don't last over the long term.
    Alex
    Alex
    i dont care about how much power it makes(in reality i dont think it will make more than 150whp) all i care about is that when i rev it to 7000 RPM the bottom end will take it. stock rods are not ment for high performance thats why the eagle rods are a good choice i seen them for around 350 bucks.
    i learned my leason...might as well spend the money now when the engine is all apart then later down the road when you blow the bottom doing 7000RPM pulls. in 2nd gear.
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Yup, there's that. I wasn't really planning on upgrading my rods, but shit, while you're spending money...might as well spend some more haha.
    Alex
    Sep 2006
    Tucson, AZ
    If you're serious about this, I'd be in as well.
    CARDONE SUCKS.
  1. 89 dx build
    By 89dxthehonda in forum Classic Honda Pics & Videos
    Last Post: 10-21-2009, 08:47 AM
  2. want to build up my car
    By cavalierboy02 in forum Forced Induction
    Last Post: 07-02-2007, 03:02 PM
  3. want to build up my car
    By cavalierboy02 in forum Classic Honda Community Chat
    Last Post: 06-29-2007, 08:44 AM
  4. please help me build a box
    By buttaz1 in forum Interior & Exterior Care
    Last Post: 04-20-2007, 09:01 PM
  5. help me build a box
    By 88 Accord DX in forum Interior & Exterior Care
    Last Post: 02-06-2004, 09:07 AM
