Just thought I would check in with my setup here...
Got the manifold and turbo mounted this weekend, planning my attack for how I will do the downpipe, and what else I will need to modify to make that happen.
In the first pic you can see the AEBS manifold and 70mm throttle body, and the sexy bracket I built so the throttle cable works. It's VERY simple Also you can see the spring I added to have a more firm pedal, I like the difference.
Planning on either doing a pie cut 2.5" downpipe that flares to 3" when its under the oil pan, or building something like this: http://www.explicitspeedperformance.net/TBS.html and not worrying about clearance and just running a full 3" dp.
If you want to see pics of anything specific let me know, hopefullly I will get the gauges redone soon and I can take some pics of that. Also working on getting the manual window conversion done. The interior is totally gutted with 2 corbeau seats, so there is not much to show on the inside.
Thats it for now.![]()
