Page 5 of 15 FirstFirst 123456789 ... LastLast
Results 101 to 125 of 363
Thread: Haunted CA3's Honda Accord 2.0Si Exclusive
  1. #101
    Re: Haunted CA3's Honda Accord 2.0Si Exclusive
    sweet!! makes me regret selling mine even though mine where only silver top ones. how well do the ports line up?
  2. #102
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    not perfect but nothing a short manifold wont fix.
    the injectors are 12 ohms ones so will be bypassing the injector resistor, modding the tps to fit ,and since the blacktop runs map sensor, the toyota manifold is set up for going straight to the factory honda map.
    just got to figure out how to work an engine stabiliser
  3. #103
    cool. just need a front engine mount that wont rip apart under load & you should be able to get away with not having that torque rod there
  4. #104
    looks awesome br0, shame its blacktop bearing runner motor parts on another blacktop but im interested to see the finished result if you actually go through with it
  5. #105
    Sep 2007
    new zealand
    an dust what do you mean by that aaron? i've got this far so i may as well keep going with it eh. dont worry bout the b16a mani at the mo eh.
  6. #106
    okay its still going to be here tho
  7. #107
    Sep 2007
    new zealand
    this is a copy of the 4age gasket with the b20a one over the top. you can see the diff in the bits coloured in with sharpie. this is one reason for needing to make a short manifold.
    the other reason is that the toyota manifold wont get closer to the head than the end of the mani studs, and the fact that those thin wee grooves you see come one from each runner and meet up at the rubber hose at the top for the map sensor. the holes on the other side of the injector cut out are for the pcv hook up. one end of teh manifold is going to be the same as the honda flange and the other will be the same as the toyota on. am going to port the injector cut outs as much as possible , just because they are going to be a couple inches further away from the valve head than i would prefer.
  8. #108
    Sep 2007
    new zealand
    YAY! won an auction for a Microtech standalone ecu yesterday.
    NZD$800 for ecu and handset controller.
    will be just the thing for running the itb equipped b20a.
    only bitch is its mapped for an mitsi evo 6.5 so will have to get the tuning done from scratch.
    will post pics as soon as i pick it up
  9. #109
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Cool. Great news man! I'd like to see how this ecu works with the B20A
  10. #110
    1991 Civic STD
    Arbutus, MD, Baby
    This thread's been around for years, and somehow I missed it.
    Well great stuff. (subscribed)
    Daily Drivers Done Right
  11. #111
    Aug 2009
    '13 Honda Civic LX
    Loudonville, NY
    Sweet man can't wait for more updates
    Flickr | Facebook
    2013 Civic Coupe
  12. #112
    sweet your getting there!
  13. #113
    Sep 2007
    new zealand
    dropped off the itbs and the remains of the honda manifold off at the fab shop today, should have a working manifold back in a day or so.
    talked to the local microtech ecu agent today, and since its programmed to run an evo motor and use mitsi sensors, i'll have to have it sent back to the manufacturer for reprogramming to accept the honda sensors etc because of the diff signals. thats gunna cost me a couple hundy but is still cheaper than buying the nz made equivilent ecu.
    hopefully have pics of both up by the end of the week
  14. #114
    Sep 2007
    new zealand
    got flash new ecu today!
    and i like the look of the standard inlet port enough not to touch it
  15. #115
    lol i notice in a lot of your pics theres always a woodys bottle lying around. that ecu is pretty small!
  16. #116
  17. #117
    Sep 2007
    new zealand
    yeah , there are the odd woodie bottle round eh.
    i do enjoy a drink while winding down in the garage, and beer makes me bloat.
    the microtech is pretty small eh.
    duz heaps tho
    will do sequential injector fire, sequential 4 coil set up, anti lag, launch control, flat shifter,vtec control, boost control up to 28 psi, injector pulse width in 100th of a millisecond intervals.............
    and te fact that its only 2 years old, not 20 odd, modern electronics are great for being so small.
    i think i could prob fit the whole ecu in the mystery black box with no worries.
    on a shitty note, the fab shop wanted like $600 to mod my manifold to suit the itbs. ummm not fuckin likely i thinks.
    so i went and bought a die grinder for match porting it all up, and i will be getting the welding and machining done through one of our out work suppliers at work for a quarter of the price.
    might take a wee bit longer but will still get done soon.
    am going to try and start wiring in the microtech loom into the honda in the weekend i hope
  18. #118
    awesome stuff
  19. #119
    Sep 2007
    new zealand
    have just about got the toyota-honda manifold adaptor finished.
    just got to tidy up the port shapes a bit more.
    got my paint organised today.
    bout $600 for everything i need to do the job.
    base coat,clear,primer, thinners,degreaser and sand paper.
    already have compressor and gravity feed spray gun.
    am looking forward to many late friday and saturday nights in the garage doing panel work.
    cant wait to get it all together and running again.
  20. #120
    sweet, that sounds like fun. take heaps of pics of the painting process
  21. #121
    Sep 2007
    new zealand
    will do eh.
    still abit of panel work to do, but now the weather is warming up i wont be so worried bout freezing my nuts off being out in the garage.
    was meant to get the paint today, but the paint place didnt have enough jet black to get the colour right. so it will be monday instead.
  22. #122
    fir enough, then you can come do mybodywork and paint, cause i HATE that sort of shit haha
  23. #123
    Sep 2007
    new zealand
    i find panel work is quite relaxing and rewarding.
    you concentrate on what you are doing and get to see the end result.
    next car after this will be either the SiR or my dads" soon to be mine" 1957 jag mk 7 sorry aaron, otherwise i would. i need a holiday eh
  24. #124
    body work is very enjoyable take heaps of pics :S
  25. #125
    im glad you enjoy it, that means your going to do a good job
    Im just going to simply sand, and paint, dents can stay haha
  1. IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012
    By RPMMARK in forum Classic Honda Community Chat
    Last Post: 09-25-2012, 10:38 AM
  2. Accord 2.0SI Exclusive... did you say digi dash!
    By carotman in forum Classic Honda Community Chat
    Last Post: 03-11-2008, 07:58 AM
  3. Wrecked 2.0Si Exclusive
    By Steve_Si in forum Classic Honda Community Chat
    Last Post: 06-22-2007, 12:18 AM
  4. New Exclusive Bodykit
    By Paul Aerodeck86 in forum Classic Honda Pics & Videos
    Last Post: 12-15-2002, 05:19 PM
  5. The SI - Exclusive I saw 20mins Ago
    By gr3k0sLaV in forum Classic Honda Community Chat
    Last Post: 08-02-2002, 05:04 AM
