just wondering, i really should know this, but i later on plan to replace the camshaft with something of more high performance. being that, i will not skimp and be replacing the valve springs and rocker arms. i was wondering if using an over head valve spring removal tool would work when taking the springs off the valve? i have done this with the OHV engines, never a OHC that i can recall. but how we did this was turning the engine till the valve was closed at TDC then puttin compressed air into the cylinder to keep the valve from falling then removing the retainer and spring. anyone done this procedure on the OHC engines? just dont want to take the head off, but if its neccesary ill just go ahead and get another cylinder head, have it rebuilt maybe with newer larger valves and assemble it off the car installing it later when its finished.
