I will apologize up front, I imagine this info is out there, but here goes. 89 honda accord, pretty sure it's the A20A1 engine, can't find the tag under all that crud. I am definately replacing the valve cover gasket (don't think the distributor gasket is bad?? but will see after valve cover gasket replacement). I noticed shortly after I start the vehicle, within 2 to 3 minutes smoke starts puffing out from under the front side of the valve cover, providing picture, it is a steady stream of smoke. I am sure some of this is from the oil that has leaked all over the engine block. I was also wondering if some of that smoke was somehow from the intake manifold??? Smoke, far as my sniffer can tell (don't stay under that smoke for too long :-) ) very oily smoke. Also under the car directly below the intake manifold shroud, while the car is running, a small amount of water drips out and within 4 or 5 inches to the right of that a real runny small spot of oil appears. Any ideas on where the water is coming from?
Long story short I guess;
Spark plugs are pretty new, don't want to replace.
Figured I would use an engine degreaser prior to valve cover gasket replace, can I leave the plugs in while cleaning?
Does it make sense to remove the intake manifold shroud before any other work? Better inspection?? Or not?
And oh well what the hell, haven't figured out Image Shack yet. Hopefully these links will work. Any info would be greatly appreciated, thanks, btw love the site.
http://img214.imageshack.us/img214/3383/dscn1305ot6.jpg
http://img529.imageshack.us/img529/1170/dscn1303el9.jpg
