shit pics dont work for me wtf!?!?!
LOL! I knew you would ask about facing with such a small bit. The only one I know of uses inserts and only gets used on the Haas. I'm still kind of a rookie at machining and our primary machinist doesn't trust me with the good stuff yet. So I just grabbed what was handy and it happened to be that. The mill has a facing cycle so I can just give it the dimensions and walk away. We do have some fly cutters though so I'll try that next time.
With that pocket, I actually was blowing it out with compressed air right when it broke. It was a 4 flute cutter so not as much room for chips to start with, and it was kinda dull already. The edges had aluminum buildup on them so the chips were sticking to it. I usually dab oil on the cutter to keep buildup down but I was having a hard time getting it in there and keeping the chips out at the same time. It was just a no win situation.
The mill is a Bridgeport EZ-Trak. It's a 2.5 axis CNC which means X/Y are full CNC and Z is manual with a scale. It's a fun machine to learn on because the controls are fairly simple yet surprisingly versatile. And it can be used as a manual with DRO when you just want to bang something out really quick.
C|
Alright, so picking up where we left off...
So after adjusting the program for a larger 2 flute cutter we can rough out the coolant port without fear of endmill homicide...
And then we come back with another 1/4" cutter to clean it up. And that completes the top side.
Here is the fixture plate I was talking about earlier. The little raised circles fit exactly into the counterbores on the top side and locate the plate correctly for machining the bottom side.
So first we dig out the coolant port.
Then we cut the grooves for the seals. And at this point right here we notice that there is a problem. The next picture shows it a little better.
If you look at hte front part of the goove you can see a dark line. That line is a shadow created by the uncut part between the groove and the port. What happened is that the port on the top side is too deep and there was not enough material left for the groove. After checking the model and program I found that there were actually two problems. One is that I cut the port too deep by .025", and the other is that there really wasn't enough clearance in the model to begin with. I thought I would have noticed this before but apparently not. This is what I meant before about having enough material for an "oh shit" part. This is an "oh shit" part.
But that's ok, we'll keep going and see what happens.
The other seal groove went fine and now all that's left is the outside contour.
And there it is. Not bad really for a first run. So now that we've found all the issues we can adjust and try again.
And here is number 2 completed. The coolant port is shallower so no chance of interference with the seal groove. And I used a fly cutter on both sides which made for a good flat surface and really nice finish.
So hey, we're done! The first set of parts is ready for testing. Angus, I don't think I have your mailing address so I'll PM you to let you know.
C|
god that's pretty... i'm gonna call him in a minute i'll tell him to come on here.
dead white and blue
Oh, and here's the finished key. Stupid board wouldn't let me post more than 10 pictures in one message. And I keep getting database errors.
C|
Nice work, i can't wait to get my hands on one.
That looks great!
I've been trying to read the update to this thread for the last 2 days but kept getting "tcp_error".
yup not bad...il post up the openloop set up...its much easyer but you have to cut the distributor
Oh yea openloop is legit setup
Amazing work, should make the distributor conversion look very pretty!
Alright kids, I should have the plate this wednesday and if everything checks out, you'll be able to get these from cygnus x-1 at the mentioned price. I will also be testing the ecu jumpers and conversion harnesses and putting them up for sale.
lol @ cutting up a distributor to make it work... sounds like a great idea... you know that a lot of atermarket distributors show up DOA right? what happens if you have no way of testing it until you cut the shit out of the housing and reweld it then put it on and it doesn't work? this is like an argument about butt connectors vs soldering. hey it works but it's not the best way to do it...
can't wait to see the plate i'm getting all giddy.
dead white and blue
Not only that, you need to grind away at the base of the thermostat housing and redrill the key. Then the vent doesn't sit right and you need to worry about water getting in there and oil if the seal ever goes. Not for me.
Hopefully you can see it installed this Saturday.
im ready to buy the kit THE VERY SECOND it goes up for sale.
i have money in hand.
-Harvey
how much the kit running for 400ish with both pieces?
i read in here somewhere i think...adaptor plate $200..dizzy key...$90
+ shipping
i could be wrong though...
-Harvey
Gentlemen, IT LIVES! muhahaha.
Only one issue though, I forgot to account for the water pipe that runs along the back of the engine. The 90º on the lower left corner hits on it. I made it work by grinding a small amount off around the lower t-stat housing bolt hole. Easily fixed, I'll get some pictures up so cygnus can make the changes.
I checked it against 3 heads, 3 distributors, and 2 thermostat housings (one of which needed to be slightly ground so it wouldn't touch the water pipe). I also checked for binding on a head with nothing but the cam and found nothing. Everything is dead on. Angle on the key is perfect, centering the distributor in it's travel when timed.
Truly excellent work Chris.
