Page 3 of 33 FirstFirst 123456713 ... LastLast
Results 51 to 75 of 816
Thread: 4g distributor adapter for obd-1 conversion
  1. #51
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    Quote Originally Posted by crucial View Post
    "A 1 7/16" ID x 1 11/16" OD x 1/8" thick"
    Is this for the dizzy hole? If so do you want it on the top and bottom? Right now the program has the d'ring and the o'ring on the bottom.
    heres what the bottom looks like with out the bolt holes
    Just on the bottom. What you have looks good.
    CARDONE SUCKS.
  2. #52
    LX User crucial's Avatar
    Sep 2007
    1988 Honda Accord LX
    Reno, NV
    Re: Blueprints?
    So is there anything else that needs attention?
    If not ill run it on Monday.
    Well let me know.
  3. #53
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    Can't think of anything else except the cam key. I'll get dimensions for that after the plate is mounted so we can get the correct offset. I ordered the viton o-rings. After we get everything sorted out, I can send you the bolts and required o-rings. I might also put some kits together for others.
    CARDONE SUCKS.
  4. #54
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: Blueprints?
    Quote Originally Posted by LX-incredible View Post
    yay :-)
    you would need rings on the other side of the plate....it wouldnt need to seal would it?
    edit: you WOULDN'T need rings on the other side of the plate....it wouldn't need to seal would it?
    '89 SE-i Coupe
    Awaiting Garage
  5. #55
    SEi User ZackieDarko's Avatar
    Re: Blueprints?
    this is awesome
  6. #56
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    yay :-)
    No, only on the back side. The thermostat housing already has a groove for a D-ring to seal the front. The dizzy has an o-ring that seals against it's hole, just like stock.
    CARDONE SUCKS.
  7. #57
    Sep 2007
    Reno, NV
    Re: Blueprints?
    0.1" deep on the back side only. A 1 7/16" ID x 1 11/16" OD x 1/8" thick o-ring will do the trick. Let's do the same around the dizzy hole as the water jacket, 0.09" lip and 0.15" groove.
    Any suggestions on o-ring material?
    http://www1.mscdirect.com/CGI/N2DRVS...00000034281040
    did you want a o'ring on the coolent port or a d'ring? A o'ring would be easier to get then the d'ring.
  8. #58
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    I want it to fit a stock D-ring. The mounting surface on the head won't allow for anything else. I suppose one could find the correct size o-ring and bend it to fit in the slot...
    CARDONE SUCKS.
  9. #59
    Sep 2007
    Reno, NV
    Re: Blueprints?
    K, programs ready to run. Plan to run it one Monday, will take some pics too.
  10. #60
    1ajs's Avatar
    slurpeepeg
    Re: Blueprints?
    dude sweetness mastercam lucky you
    you ever use inventor or autocad?
  11. #61
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    Sweet, thanks man!
    CARDONE SUCKS.
  12. #62
    AZ
    Re: Blueprints?
    damn angus you're serious about this ish! just kidding man this is gonna be sweet.
    dead white and blue
  13. #63
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    Yes it is.
    CARDONE SUCKS.
  14. #64
    AZ
    Re: Blueprints?
    you'll have to show me when you get it you know.
    dead white and blue
  15. #65
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    Of course.
    All that would be left is the cam key. I'm going to try and find a 4g at the yard monday with the dizzy attached, see how it lines up at TDC, and find out what offset is needed when I get the plate. Should be easy, provided they have one there...
    CARDONE SUCKS.
  16. #66
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Re: Blueprints?
    Yay, good to see the R&D forum getting some solid use
  17. #67
    Sep 2007
    Reno, NV
    Re: Blueprints?
    So i talked to my girlfriends dad today and he said he would ship the part(s) for me. So that saves on the shipping costs. He said he would use fed x next day cause thats all he ever uses.
    So after were done with this project I hope someone else has been inspired to wanna make something, I'm always up for a good challenge..
  18. #68
    2drSE-i's Avatar
    Oklahoma City
    Re: Blueprints?
    do you have any interest in making strut bars? because if so i may start getting some measurements.
    '89 SE-i Coupe
    Awaiting Garage
  19. #69
    Re: Blueprints?
    he has access to a machine that can do 3D scans of an object
    exact replica DC bars anybody?
  20. #70
    AZ
    Re: Blueprints?
    nice! me and lx-incredible went to the yard today and he took a look at a 4g distributor so he should have that shit figured out. so obd1 swaps should be pretty easy soon.
    dead white and blue
  21. #71
    Re: Blueprints?
    i was thinking of making the trim around the door handle out of aluminum i can supply the plate thick enough. would that be scannable? talking about the inside part, the plastic one that looks like crap. with all the interior work on this car that would look awesome. would you need one edge squared in the bridgeport first?
  22. #72
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Re: Blueprints?
    so where the pics of the finished product?
  23. #73
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    Yup, picked up a PR4 as well. Thanks again buddy!
    CARDONE SUCKS.
  24. #74
    Sep 2007
    Reno, NV
    Re: Blueprints?
    No part today. Didn't have any open machines to run it on, the job im working on should be done tomorrow. So hopefully ill have something for you to look at. Sorry about that.
  25. #75
    guaynabo89's Avatar
    FL
    Re: Blueprints?
    lol
    yeah definately get those pics up. Its real nice of you to offer this service.
  1. help! Hitachi distributor and/or module and/or a conversion
    By senor honda in forum 3geez Accords
    Last Post: 02-19-2013, 02:03 PM
  2. distributor conversion?
    By stocklxi in forum Restoration & Custom Fabrication
    Last Post: 10-07-2007, 01:50 PM
  3. CARB TO EFI / EFI TO CARB Distributor Conversion
    By A20A1 in forum Carburetor Tech
    Last Post: 08-29-2006, 06:08 PM
  4. distributor conversion questions
    By mouchyn in forum Performance
    Last Post: 11-17-2004, 10:44 PM
  5. Replies: 3
    Last Post: 09-06-2003, 01:03 PM
Tags for this Thread
