Page 8 of 33 FirstFirst ... 45678910111218 ... LastLast
Results 176 to 200 of 816
Thread: 4g distributor adapter for obd-1 conversion
  1. #176
    LX User crucial's Avatar
    Sep 2007
    1988 Honda Accord LX
    Reno, NV
    Re: Blueprints?
    Yeah if i could see a pic that would help
  2. #177
    Sep 2007
    Reno, NV
    Re: Blueprints?
    So heres the placement of it moved over x.1 and y.1.
    And of the new dimensions.
  3. #178
    Sep 2007
    Reno, NV
    Re: Blueprints?
    And the C' bore dimensions.
  4. #179
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    CARDONE SUCKS.
  5. #180
    SEi User ZackieDarko's Avatar
    Re: Blueprints?
    Quote Originally Posted by LX-incredible View Post
    sweeeeeeeeeeet
    how close to done is this?
  6. #181
    Sep 2007
    Reno, NV
    Re: Blueprints?
    Looks pretty cool on there even for being a bad part. I think it will work by moving the indent over x0.1 & Y0.1 . So should i run it or is there any thing else to adjust or change.
  7. #182
    LX User fogged's Avatar
    Jul 2007
    89 LXi Coupe 5spd
    Olathe Ks.
    Re: Blueprints?
    I dont mean to be such a newb, but can someone give me a link so I can understand just what you gain from this mod. Once again sorry for being such a newb.
  8. #183
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: Blueprints?
    no biggie fogged. With this part, you can easily and more effectively run a 4th gen, ECU controlled distributor, in conjunction with an OBD-1 ECU and wiring harness swap. This allows tuning and more reliable ignition timing.
    '89 SE-i Coupe
    Awaiting Garage
  9. #184
    Jul 2007
    89 LXi Coupe 5spd
    Olathe Ks.
    Re: Blueprints?
    Thanks for clearing that up for me. In that case. Way cool.
  10. #185
    2drSE-i's Avatar
    Oklahoma City
    Re: Blueprints?
    np, 2DrSE-i newb coordinator strikes again!
    '89 SE-i Coupe
    Awaiting Garage
  11. #186
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    Well, I couldn't find the correct spacers to mount it properly, so I found a hole saw and went to town.
    We now have a piece with the correct offset. I can give you the measurements for the stock key and the angle of the offset. It would be best if you could give me the exact thickness of the plate being used, as the one you sent wasn't 3/4". Thanks.
    CARDONE SUCKS.
  12. #187
    Re: Blueprints?
    yaurrr!
  13. #188
    Re: Blueprints?
    jessus thats looking good
  14. #189
    LX User 87preludeA20A3's Avatar
    1987 Honda Prelude
    Southern Cali
    Re: Blueprints?
    Man that is sick, i haven't seen anything so cool for our cars in a while. Good work guys.
  15. #190
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    Quote Originally Posted by ZackieDarko View Post
    yaurrr!
    Sorry, I missed your previous post. A new plate and key will need to be made and tested. When everything checks out, we will figure out the cost, and buy the plate. Hardware and O-rings come out to around $5, I believe the plate was around $16, there's the material for the key, and I think cruical deserves something for his hard work. Your guess on the time is as good as mine.
    CARDONE SUCKS.
  16. #191
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    Quote Originally Posted by crucial View Post
    The thickness of the plate that you sent was 0.69" at the top and 0.72" at the bottom, so that needs to be addressed. Then there's the coolant passage, but I think you have that figured out. Everything else looks good.
    CARDONE SUCKS.
  17. #192
    Sep 2007
    Reno, NV
    Re: Blueprints?
    The part will be .75 thick, I just milled the part i sent you to clean it up. Didn't want to send you something with burs all over lol.
    So i think ill run a complete part to send you, and start working on the key for it.
    I also got a couple plates too use so might be able to send a few of them. But first thing first is to get you a complete part for testing and such.
  18. #193
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    Cool. I'll have the key measurements tomorrow.
    CARDONE SUCKS.
  19. #194
    Re: Blueprints?
    nice.
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    The pin hole is perpendicular to the key teeth on the stock key.
    The ring groove and pin hole need to be moved down 0.75" and offset around 70 degrees or so... I'll figure that out later.
    CARDONE SUCKS.
  21. #196
    SEi User
    Feb 2004
    Panama City, FL
    Re: Blueprints?
    Nice work! After you get one of these up and running I think I'm going to have to buy one.
    Pgm-fi conversion 4-16-05
    OBD1 11-25-06
    Turbo 2-26-07
  22. #197
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    Re: Blueprints?
    Yeah I won't be needing one of these (though I wish I was, I would love to support this work), but I gotta commend you all on your dedication and cooperation to actually make something useful from the ground up!
    I think we might be able to get you to build different strut mounts to allow us to run the civic strut conversion with a little less hassle.
  23. #198
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    CARDONE SUCKS.
  24. #199
    Sep 2006
    Tucson, AZ
    Re: Blueprints?
    That should be it... Let me know if you need anything else.
    CARDONE SUCKS.
  25. #200
    AZ
    Re: Blueprints?
    lookin tits angus... keep it up.
    dead white and blue
  1. help! Hitachi distributor and/or module and/or a conversion
    By senor honda in forum 3geez Accords
    Last Post: 02-19-2013, 02:03 PM
  2. distributor conversion?
    By stocklxi in forum Restoration & Custom Fabrication
    Last Post: 10-07-2007, 01:50 PM
  3. CARB TO EFI / EFI TO CARB Distributor Conversion
    By A20A1 in forum Carburetor Tech
    Last Post: 08-29-2006, 06:08 PM
  4. distributor conversion questions
    By mouchyn in forum Performance
    Last Post: 11-17-2004, 10:44 PM
  5. Replies: 3
    Last Post: 09-06-2003, 01:03 PM
Tags for this Thread
